IC PUMP
Old Oct 12, 2009 | 04:42 PM
SPIKES's Avatar
2019 S63 COUPE
IC PUMP
hi
just got an 06 e55 on saturday. drives fine but not sure if i am getting all the power. i read threads about ic pump going bad.
is there a way to test it as i dont have a comparrison with another 55?
i have to go to dealer as dvd is stuck in comand....can they test the pump.
thanks
Old Oct 12, 2009 | 04:50 PM
Full Throttle's Avatar
CLS55 AMG
Originally Posted by SPIKES
hi
thanks
Change out your pump.
Old Oct 12, 2009 | 05:51 PM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
Riding motorcycles makes me a little jaded in the power delivery department so every now and then I'm convinced my IC pump is bad (even have a spare sitting in my office for when it goes). When I'm questioning if said pump is bad I perform a test that was recommended on this forum a while back - 1) turn off traction control 2) floor it - if you smell smoke and go sideways - the pump is fine; chirp the wheels and go straight - your IC pump is bad. A little unscientific, but its worked for me so far.
Old Oct 12, 2009 | 06:47 PM
SPIKES's Avatar
2019 S63 COUPE
thanks....did that yesterday...car will hardly chirp and run straight with traction off
how come the pump affects performance so much? what does it do?
Old Oct 12, 2009 | 08:18 PM
motorkas's Avatar
I honestly don't know - I think it flows water to the supercharger keeping temps down - if the temps get too high - the supercharger will shut off basically leaving you with a regular 5.5 engine. Its a very common problem. . . luckily the part is maybe 150.00 and its a real easy fix from everything I've read.
Old Oct 12, 2009 | 08:36 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
the ic pump circulated the coolant beneath the s/c in order to cool the intake air charge. If the ic pump is bad IAT's spike, timing is pulled and you loose power.
Old Oct 12, 2009 | 09:48 PM
SPIKES's Avatar
2019 S63 COUPE
thanks
Old Oct 12, 2009 | 09:49 PM
SPIKES's Avatar
2019 S63 COUPE
well said...thanks
Old Oct 12, 2009 | 09:56 PM
2003 S600's Avatar
2003 s600
Find the pump behind small amg grille on passenger side, feel inlet hose when engine is on. If you feel vibration, it is working. If no it is bad.
Old Oct 13, 2009 | 04:14 AM
Ohbev's Avatar
E55 AMG Kompressor
If the ic pump does not work all the time. Then when does the ic pump turn on. When you are flat on the throttle does the ic pump turn on then ?
Old Oct 13, 2009 | 07:25 AM
2003 S600's Avatar
2003 s600
It is always on in my car, when the engine is on. Your car I heard may have to rev to 2000rpm then it turns on, also may have temp switch activation. I have replaced my intercooler hoses with clear hose so I can pop the hood and look at the flow.
Old Oct 13, 2009 | 11:53 AM
Infiniti's Avatar
a unicorn tuned p30 e63
How much of a difference is there with the pump? I just got my E55 and i dont fool around with it much the day i decided to do so i couldnt get past two 1-3gear runs and the s/c shuts off, i kept fooling with it s/c shutting off left and right.
Old Oct 17, 2009 | 10:33 AM
SPIKES's Avatar
2019 S63 COUPE
drove it again this morning....disappointed.....traction off and it hardly wheel spins!!!!
how do i know if it is right.....
help
Old Oct 17, 2009 | 10:36 AM
slownrusty's Avatar
'06 E55 K2
If your car is under warranty still take it the Dealer and they will test it. I recently bought an '06 and I dyno'd it to see the power the car was making to ensure the pump was healthy, as low dyno numbers = a failing or failed pump.
Yasin
Old Oct 17, 2009 | 10:51 AM
Karlson's Avatar
06 E55
My car revs to 1800-2000 rmps when starts, but after 15 seconds it gets back to normal
Old Oct 17, 2009 | 12:21 PM
myntk12's Avatar
2004 E55 AMG
help
With it off you should be able to shred your tires and go sideways down the street. Change the pump.
