New E55 owner
Old Oct 18, 2009 | 09:52 PM
rluvsbenz's Avatar
2006 E55 Designo 1991 190E 2.3 2000 BMW 740i 1987 PORSHCE 928S4
New E55 owner
Based on these specs the E55 400lbs lighter than the CLS55 with same HP but it shows that E55 is slower.
Can someone make sense of what I read at the Car and Driver review? Also it show E55 limited although I've driven the car 160MPH +
http://www.caranddriver.com/reviews/...t/specs_page_2
http://www.caranddriver.com/reviews/...w/specs_page_2
Mercedes-Benz CLS55 AMG - Specs
ENGINE TYPE: supercharged and intercooled SOHC 24-valve V-8, aluminum block and heads, port fuel injection
Displacement: 332 cu in, 5439cc
Power (SAE net): 469 bhp @ 6100 rpm
Torque (SAE net): 516 lb-ft @ 2650 rpm
TRANSMISSION: 5-speed automatic with manumatic shifting
DIMENSIONS:
Wheelbase: 112.4 in Length: 193.5 in Width: 73.7 in Height: 54.7 in
Curb weight: 4327 lb
C/D TEST RESULTS:
Zero to 60 mph: 4.2 sec
Zero to 100 mph: 9.7 sec
Zero to 150 mph: 23.7 sec
Street start, 5-60 mph: 4.6 sec
Standing 1/4-mile: 12.5 sec @ 115 mph
Top speed (governor limited): 157 mph
Braking, 70-0 mph: 163 ft
Roadholding, 300-ft-dia skidpad: 0.88 g
E55
ENGINE TYPE: supercharged and intercooled SOHC 24-valve V-8, aluminum block and heads, Bosch Motronic ME2.8.1 engine-control system with port fuel injection
TRANSMISSION: 5-speed automatic with lockup torque converter
DIMENSIONS:
Wheelbase: 112.4 in Length: 190.9 in Width: 71.7 in Height: 50.9 in
Curb weight: 3900 lb
C/D-ESTIMATED PERFORMANCE:
Zero to 60 mph 4.5 sec
Zero to 100 mph 10.5 sec
Standing 1/4-mile 12.4 sec
Top speed (governor limited) 156 mph
Old Oct 19, 2009 | 12:49 AM
jturkel's Avatar
02 C32 AMG
traction issues with the E55 explains this small discrepancy i guess you are seeing in 0-60 and 0-100.
if your car goes above 160, then it is possible you have a tune on your car already that has deleted the factory speed limiter/governor.
Old Oct 19, 2009 | 09:05 AM
rluvsbenz's Avatar
How can I tell if I have a tuned car? I bought the car from MB with CPO. Should this disqualify this car from MB's CPO program at the time of purchase?
Old Oct 19, 2009 | 10:46 AM
scowil's Avatar
e55
the CLS55 are actual test results where as the E55 are estimates.
