Wheel Vibration
I had the same issue and tried the same rebalancing of the wheels.
Only after I had the wheels repaired, did the problems go away.
1. Tires get a little flatspotted on trip from Germany. Drive it for a day or so and it will get better. (by the way they must think I am an idiot who never had high perf cars before). Suprise never got better. They rebalanced tires and said all was well.
2. Tires were out of round. They replaced all 4 tires. Said all was better.
3. Said it was a bent wheel and tried to cahrge me for it. I pointed out that the problem was evident from the time I picked up the car. They said "oh, sorry". They then exchanged wheels and tires from another E55. Manager drove it and problem persisted. Old wheels back on.
4. Drive shaft out of balance. New drive shaft installed. Problem persists.
5. Said that all high performance cars with wide tires do this and is normal. I again pointed out that I was not the idiot.
6. Factory toe-in settings caused the scrubbing of the tires which caused vibration. Adjusted alignment and there was some improvement.
7. Rubber bushings in suspension have too much play for the wide tires. Replaced with special euro spec polyurathane bushings. Got a little better.
8. I bought Bridgestones and got rid of Contis and problem got a little better.
9. Eventually gave up trying to solve issue. I still loved the car though. Have been without MB for about 2 years. Recently picked up '09 SL 550. Vibration issue resolved....
Good luck!
