Airline repair and valve block question
2004 E55 AMG
Curious how many have repaired one of their air lines, also anyone with issues with the airline valve block? It does not appear to be as problematic as the struts and compressor based on threads there.
I was inspecting mine and noticed all of the lines had a small leak at the block and the primary pump line at the pump (spraying water), so I removed them, moved the collar and reinstalled. Perfect- no leaks.
