Hitting the track tomorrow
I did not get a chance to run my car bone stock but my mods are only
low temp t-stat
modified torque convertor
Quaife diff
Drag radials.
I am running at Lebanon Valley in New York,not hte best track by far as far as air quailty,but the temps will only be in the mid to high 40s
Gotta remember to reset the ECU before I leave
with and without sticky tires?
Curious how much better the 60ft will be with the loose convertor,well as long as the tire stick,the convertor hits extremely hard off the line
Exp tells me if it sticks the best 60ft with this car will be from a idle to wot or possibly bring it up to 1400-1500 and going wot.
Trying to hold the car at 2500 and launch I do not think will net the best 60ft,but i wil try it regardless.
What have you found to be the best for your setup?
netting a 1.6 are you using a stock convertor?
did you do a pulley change? if so im sure your power comes in earlier
with the larger pulley
Going WOT from 1200 the convertor probably only hits 1600-1700 instantly,but leaving from 950 it flashe higher most likely around 1850-1900 getting you further into the torque curve,any 1.6 is really good
Bringing it up to a few hundred over idle first is a very smart move
first pass ever was a 12.20 at 110,car was pretty well heat soaked at this point
Let it sit for an hour and went back up and went 12.13 at 113.1 60 ft was a 1.74
Car didnt spin at all,but the tires i used were a bit tall taking away some rear gear.
the car didnt like the taller tires IMO as we already have tall gear out back.
I am now gonna look into some type of fan over ride as even with a lower temp t-stat
sitting and waiting the car will get hot and wait for the factory fan setting and gonna fabricate some type if intercooler resevoir under that hood to seperate the fluids.
not really into a huge tank out back but seperating them has to be great for racing.
also gonna setup mini fans on hte heat exchanger also over the winter.
Working on opening my own shop right now and wnat to make some items for these
cars that are worthwhile.
If your sitting around with hte car running wven with a low temp t-stat the factory fans wont come on till its hitting over 200* which means you heat exchanger has to cool off 200+* water regardless of its size.
Which is why seperating hte sytems will work well,and if there is room
for dedicated fans on the heat x changer it will work killer especially on days like today.
I watch my IAT with a scanner and if I drive for a bit in the cool weather my IATs will only get as low as 90*.
im betting i can get that way lower,and the lower that number starts the lower it will be at the big end.
believe it or not in front of the stock unit. Then the trunk reservoir.
