Is Anyone Running 285/35/18's on a W211 E55 AMG???
Old Oct 30, 2009 | 01:58 PM
MOROSO55's Avatar
2006 WHITE RENNTECH E55
I am looking to go wide and have my eyes on a cheap pair of 285/35/18's for my 06' E55 that has stock suspension and stock rims. Does anyone know for a fact that these will fit with out crazy rubbing and whatnot?
Old Oct 30, 2009 | 04:42 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
PM Shardul, He has run that set up on 9.5" MB rears. A few others have as well.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 30, 2009 | 04:44 PM
kiamcoj's Avatar
2012 CLS63
Not sure if you're interested, but I'm helping a fellow forum member sell this set:
https://mbworld.org/forums/wheels-ti...ock-tires.html
Just let me know and maybe we can work something out since they need to be shipped. Thanks!
Old Oct 30, 2009 | 05:11 PM
gago1101's Avatar
2012 CLS63 AMG Weistec
I have 285/35/18 on stock wheels- 2005 E55. they are Pirelli-P zeros. running perfect.
Old Oct 30, 2009 | 09:43 PM
komp55's Avatar
ML550
FWIW, 285's are not a specified fitment for 9" rims. They require a 9.5" rim; otherwise the sidewall are pinched in, stressing them in a way they were not designed for. Just because a tire can be mounted on a rim doesn't mean it's right to actually use on that rim.
Old Oct 31, 2009 | 07:38 PM
1 BAD BURB's Avatar
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
i used to run 295/35/18 on my 9.5" wide rear rim...
Old Apr 3, 2016 | 04:26 PM
BlackHammer's Avatar
2006 E55
Does anyone have pictures of how this set up looks on the stock 18's?
Old Nov 25, 2018 | 11:32 AM
Pd9264's Avatar
E55 amg w211
now it’s saying bank 1 sensor 2 fault.
plus map sensor.
could a faulty map sensor also through a o2 sensor fault
Old Nov 25, 2018 | 08:16 PM
FunkTron's Avatar
2006 CLS55
plus map sensor.
you get the bank 1 sensor 2 fault caused by to wide of tires on too narrow of a rim....according to this thread.
Old Nov 26, 2018 | 10:22 PM
Notdke9fdkfjekrjrkj123's Avatar
Last edited by Notdke9fdkfjekrjrkj123; Nov 26, 2018 at 10:26 PM. Reason: Wrong thread?
Old Nov 27, 2018 | 05:42 AM
zhmorrow13's Avatar
W211 E55 AMG
plus map sensor.
try mounting the tires on the front rims and see if that solves your map sensor issue. Worked for me but YMMV
Old Nov 27, 2018 | 08:49 AM
MACEDON's Avatar
05 E55, 98 CLK320
old thread is old
Old Apr 5, 2020 | 11:30 PM
zhmorrow13's Avatar
W211 E55 AMG
this made me lol thanks
