San Antonio Raceway Midnight Madness 11.14.09 - 2x 211 E55k's go mid 12s at 113ish.
Old Nov 15, 2009 | 06:17 AM
GT40MkI's Avatar
2005 E55 / 2001 e39 M5
2x L.E.T./Eurocharged/Code3 211 E55k's go mid 12s at 113ish.
Ran out to the track on a whim with lackluster results...granted, we went to have a good time without much prep (or checking the weather). We both feel like the cars are missing 4-5 mph on the big end and are open to ideas.
It was cool- about 74*, but 100% humidity. I didn't bring my laptop so I wasn't able to log- but my air fuel seemed to be around 11.00 at WOT every time I checked the gauge, and my IATs got up around 160 on the last pass off the night on the big end. Possible the Heat Exchanger doesn't work very well in high humidity?
My car:
Eurocharged 172mm pulley
LET Tune
Code3 HE and CM30 pump
180? Thermostat
Secondary Cats and Resonator Deleted.
20" Monarch Euro 63 Wheels
106k miles. 2005 model
His car:
ASP 178?mm pulley
LET Tune
Code3 HE and CM30
LET? Shorty/log style Headers into stock cats and resonator.
19" HRE 547 Wheels on radial tires
90k mile 2004 model
First run (mine/his):
60- 2.19/2.09
330- 5.58/5.43
1/8et- 8.33/8.14
1/8mph- 89.02/90.27
1/4et- 12.73/12.49
1/4mph- 112.67/113.09
Next pass I opened up my dry 20 shot to try and even up the tables...only used a little in 3rd gear to stay out front.
Second run (mine/his):
60- 1.94/2.05
330- 5.24/5.41
1/8et- 7.94/8.15
1/8mph- 90.45/89.30
1/4et- 12.28/12.52
1/4mph- 113.61/113.52
Open to thoughts, ideas, suggestions...please refrain from "Use the drag radials you have sitting in the garage." or "why didn't you use the 150 shot instead?" :-) Should have a video of the first pass up tomorrow-thanks!
Old Nov 15, 2009 | 12:08 PM
GT40MkI's Avatar
Anyone?
Old Nov 15, 2009 | 12:20 PM
Benz-O-Rama's Avatar
I would think with your mods, minus the cheater bottle , you should be trapping 116+
I'm basing that on a buddy's stock(ish) SL55. The only thing that car has is a LET/Eurocharged shelf tune, that's it. I was able to pilot that car to a 12.03@114
Did you get the tune first, or after your pulley and cooling mods? You know where I'm going with this. The tune should be last, and it should be a custom dyno tune after your bolt-ons.
Old Nov 15, 2009 | 12:34 PM
GT40MkI's Avatar
Tune was last- this car went 12.2@120 on a 2.3 60ft hot lapping without the bottle with the same mods a few months ago on an 80* night. Wondering where my 6mph went. Different track. maybe 1-2mph, different wheels (heavier than stock 18s?) maybe a few mph...just seems odd...
Old Nov 15, 2009 | 12:38 PM
GT40MkI's Avatar
And also I'm happy wiith the 11.00 A/F...it creeped up to 11.50ish on the little bottle, but still safe and where I'd want it...
Old Nov 15, 2009 | 06:44 PM
AMazinGocity's Avatar
S55
There seems to still be alot to gain in your 60' without going to other tires. What was your tire pressure?
Different question how long did you wait in between runs?
Old Nov 15, 2009 | 06:54 PM
GT40MkI's Avatar
As humid as the track was, I tried to feather/roll into the throttle...resulted in a 2.7...these runs were with ESP on, rolling into the throttle.
Tires were Vredestein 20" radials at 40psi on mine...I'd guess about the same on his.
Old Nov 15, 2009 | 06:57 PM
GT40MkI's Avatar
We weren't hot lapping...I'd guess about 30 minutes between passes.
Old Nov 16, 2009 | 11:26 PM
TopGun32's Avatar
I have found that any HE set up with out separate coolant circuit, will not perform as well.
I finally got around to do it... and its make the biggest difference.. specially for pullies over 172mm..
I would buy a separate reservoir and remove that T splitter that connects your engine coolant and IC coolant.
I also have the T-stat mod.. and that really don't help either.
100% will definitely will take away power.. since cars like dry air for better combustion.
Old Nov 17, 2009 | 12:45 AM
GT40MkI's Avatar
Yeah, separating the cooling system is on our mod list for this weekend...thanks for the confirmation! Of course we had a front blow through last night and temps dropped about 30 degrees...humidity is gone. Looks like we need to head back out to the track
Old Nov 17, 2009 | 10:36 AM
Eraser-X's Avatar
21 E450 Wagon and 07 SL55
You need to let me know when you guys are going back I will try to make it. I have never tried drag racing so I guess it is time now.
Old Nov 17, 2009 | 10:58 AM
skratch77's Avatar
2005 E55
with your laptop,can you log a/f ratio?
Old Nov 17, 2009 | 11:09 AM
myntk12's Avatar
2004 E55 AMG
for comparison sakes, what were other cars running; would give an indication of the track that evening
Old Nov 17, 2009 | 11:34 AM
kindafast's Avatar
W210 E55 & W204 C63
I ran a 2.0 60ft and traped 123 @11.8 in the Vette, humidity was bad and the temperature in the low 70's.
It was the first time I saw an AMG there besides mine, usually its just a redneck fest. Here is a crappy pic I took with my phone.
Attached Thumbnails San Antonio Raceway Midnight Madness 11.14.09 - 2x 211 E55k's go mid 12s at 113ish.-random-010.jpg
Old Nov 17, 2009 | 01:46 PM
GT40MkI's Avatar
Thanks for grabbing a pic man.
I can log up to 4 channels from the odbII + my wideband to the laptop-when I bring it along.
Typically I'll watch IAT, TIMING, RPM, MAP pressure and wideband...any suggestions on the mix?
Old Nov 17, 2009 | 11:59 PM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
the one on the left is sexy
Old Nov 18, 2009 | 12:45 AM
GT40MkI's Avatar
We're the second race in this video...decided to have a little fun with the event coordinator.
