Star Diagnostic How To DIY with lots o pics
Old Feb 23, 2013 | 07:59 AM
  #626
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by DVC
Does anyone know what changes to Airmatic are made with the ROW setting?
I noticed after sitting at a stoplight for a few minutes, it raises up noticeably. It didn't do this before.
None whatsoever. Perhaps your speed had been greater than 62 MPH prior to stopping. This will cause the airmatic to lower the car about 3/4" if the ride select was in comfort mode above that speed.
Old Feb 23, 2013 | 10:48 AM
  #627
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
That's it, thank you Ag. Was in Comfort and coming off of 62+MPH. Also, had the radio/nav off to listen to the newly installed MBH headers. Perhaps that's why I was never aware of this before. I appreciate it!
Old Mar 1, 2013 | 01:33 PM
  #628
1badassbenz's Avatar
Mercedes
Key programming
Can't seem to find anything when I search. Is there any way to program key fobs with the star system?
Old Mar 1, 2013 | 01:36 PM
  #629
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
No you can't. I think that is another system.
Old Mar 8, 2013 | 10:21 AM
  #630
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Originally Posted by xpl0sive
looking for some help from you guys. i've got two issues.
My first issue is that when i go into Development mode for my ECU I get the following error:
and then it goes in and ALL of the settings are blank
has anyone had the same issue before? I can go into actual values and it will show me the current settings there just fine....
so whats my issue here? do i need to recode it all?
second question is... is there Dev mode in the IC- instrument cluster module? I can go into Dev mode on every other module but the cluster...
A this has become a convoluted thread with many questions and few answers (folks like secrets here to pay the bills); concerning the above, when I run into this exact issue, I unplug everything, unplug the OBDII, reboot PC, then try again, Almost always works after and the fields are populated. I keep the car off with key out for a minute.
Old Mar 13, 2013 | 09:51 AM
  #631
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
PP keep the engine running and try to see if the fields populate the first time.
Old Mar 17, 2013 | 07:15 PM
  #632
FromM3toAMG's Avatar
07 E63
Perfect!
Old Mar 17, 2013 | 10:10 PM
  #633
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
The other way I have found that works pretty consistently is to read coding first (as if you are going to transfer to another unit), then try this again. Works for me every time
Old Mar 23, 2013 | 04:08 PM
  #634
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
I actually think it does change some things.... Check this out..
http://bayhas.com/mercedes/w211/cont...velcontrol.htm
look at the chart on the bottom....
Old Apr 2, 2013 | 04:05 AM
  #635
standman123's Avatar
Mercedes C55 T AMG
question
Hi all,
I have a question. I have a Mercedes C55 AMG T and Star Diagnosis Developer.
Like my Vmax would lift or remove.
I was already in the engine control unit with developers because it says invalid encoding exist! the code 0224 can lift the Vmax to 280! But if you do it and test it sealed off at 250!
Does anyone have an idea?
Thank you
Old Apr 5, 2013 | 05:56 PM
  #636
seven6zero's Avatar
W211 E55
Has anyone been able to turn off "Don't forget key chime" using STAR?
Old Apr 6, 2013 | 10:46 PM
  #637
MAN55LE's Avatar
04 E55 AMG
I don't have keyless go....but I think if you set it car to ROW ...not sure ....I know people have done it with STAR
Old Apr 11, 2013 | 02:03 PM
  #638
more_amg's Avatar
2015 S550 coupe, 2024 GLC43
how to shut TPMS
Can somebody advise how to shut down the TPMS in my E55, please! Need help, guys!
Old Apr 13, 2013 | 11:34 PM
  #639
07 E63
so im sitting in my car trying to figure out how to disable the active cornering fog.. anyone know how to do this? the only time i want my fogs on is when i turn them on..tired of people trying to tell me i have a have a fog light out...
Old Apr 14, 2013 | 09:33 AM
  #640
AgSilver's Avatar
Easy to do with DAS. Do you have access to DAS?
Old Apr 14, 2013 | 12:20 PM
  #641
07 E63
Yeah i do, im just not able to find the where or how to do it. ive gone through just about every available menu.
Old Apr 14, 2013 | 06:52 PM
  #642
07 E63
Can anyone help me out with this? the owner of the DAS wants it back asap.. today is pretty much my last day to be able to do this. oh and id also like to disable the NAV warning at initial start up.
Old Apr 21, 2013 | 10:31 PM
  #643
westu93's Avatar
'04 E55 AMG
Anyone in the bay area willing to share their STAR or know mechanic that has one? I am willing to pay.
Old Apr 21, 2013 | 10:32 PM
  #644
westu93's Avatar
'04 E55 AMG
Also, is there a way i can see the DIY mod pictures in this thread without having to find it through all the posts?
Old May 10, 2013 | 04:25 PM
  #645
more_amg's Avatar
CAN'T SHUT DOWN THE TELE AID
If somebody can help, I will really appreciate it. I'm trying to shut down the Tele Aid. In CGW menu, when I'm switching it to "NOT PRESENT", it will not let me do it. Any thoughts? I'm tired of this annoying mafunction.
Old May 16, 2013 | 02:02 AM
  #646
SoCal_AMG350's Avatar
'05 E55, '82 Porsche 911SC, '83 DeLorean
My question is this: I've read where the airmatic system will automatically lower the car after reaching highway speeds in Comfort Mode, or something to that affect. If I lower my E55 to my desired height, will the system still lower it further when I reach highway speeds? I don't want my car looking like a corny muscle car with the back end raked in the air going down the freeway. Or worse, lower it automatically to where it rubs the fenders.
Old May 16, 2013 | 06:39 AM
  #647
GregMB's Avatar
My understanding is that the suspension will lower the car in all suspension modes, not just Comfort. If memory serves the trigger point is 68mph, and the car will drop by 15mm (comfort mode) and 10mm (sport and sport 2). If your car was in Raised Mode, that will also be disabled at highway speeds.
I'm not sure if there is any way to disable it in Star, or if the aftermarket ELMs (Renntech or Programa) will override those factory behaviors.
-G
Old May 26, 2013 | 01:29 PM
  #648
RavenMDX's Avatar
2009 C300 4Matic Sport + Premium 2
Hi, where is DAS or Xentry can I enabled the "do not forget to close sunroof" IC cluster message for my W204?
Old Jun 2, 2013 | 11:06 PM
  #649
malahhaor's Avatar
06 Carrera4
aliexpress.com is about the only link that still works in this thread.
Is anyone interested in selling their Star? (with latest updates hopefully ) id rather get something that has been proven to work.
Old Jun 3, 2013 | 12:07 AM
  #650
AgSilver's Avatar
http://ecartool.com/
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
