Star Diagnostic How To DIY with lots o pics
F:\Programm\Xentry\bin
GlobalSystemSettings_install.properties
DAS config settings
path2DASContextFile=$DAS_TEMP_DIR replaece to
path2DASContextFile=F:\\userdata\\DAS
DAS config settings
DAS config settings
DAS config settings
Xentry version:
22.10.2.6
03/2018 Release
1.3.4.1 CAESAR
8.14.12 Softing
Here are my current settings...
Current Settings
"Tire Pressure Loss Warner can be activated through stardiagnose on any 2006 W211...no parts needed, it gets it's reading off ESP - just some version coding - no reading of airpressure in the IC, just a warning when the pressure of one of the tires drops too much.
Tire Pressure Monitor System is the more active system that has its own control module, 4 antennas, 4 senders and pressure readings in the instrument cluster...this can be retrofitted in any W211 and costs approx 2000USD to do so"
It was working perfect the night before and all I did was go on the simulator to look around....who knows what happened.
Does anyone know where I could disable this "feature" using Xentry?
Also, I had a cable harness installed behind the COMAND that enabled me to close all the windows, sunroof and the lift back, I have a station wagon, with one push of a close button on the key fob (didn't need to hold the button until everything closed).
I had to remove the cable harness so I'd like to enable this function via Xentry.
Could anyone offer some advice?
Thanks.
The second question I didn’t understand what you want but why a switch? Flash your car with the proper firmware and you can open and close the rear gate with your key FOB.
I though that chime only sounded in Japanese spec cars, not in the US.
When I had the cable harness installed I could just press the close button once and walk away from the car, everything closed automatically, windows, sunroof and lift gate, if it was open (I have a power lift gate). Of course the car doors also locked.
The same in reverse as well, I pressed the open button twice and all the windows and sunroof fully opened, not the lift gate of course.
Normally we have to keep pressing the close button to close everything or the open button to open everything.
How about disabling the ECO On/Off button?
That's possible with Xentry, correct?
If I flash the firmware do I need SCN coding?
