Star Diagnostic How To DIY with lots o pics
Rating: Thread Rating: 15 votes, 5.00 average.
Old 05-06-2019, 07:07 PM
  #1301
Mackhack's Avatar
Originally Posted by zhmorrow13
Okay so what’s the error about? I can still use other functions fine
I can do a lot remotely but miracles take a little longer. My crystal ball is in the shop right now for calibration. Sorry.
Old 05-06-2019, 07:24 PM
  #1302
zhmorrow13's Avatar
W211 E55 AMG
Maybe your calibration guy can also calibrate my airmatic
Old 05-11-2019, 11:31 AM
  #1303
panam93's Avatar
CLS 500 w219
Merci pour ce post qui m'a bien aidé
Old 05-15-2019, 08:53 PM
  #1304
zhmorrow13's Avatar
W211 E55 AMG
How to do I disable this message?
Via DAS
Old 05-16-2019, 06:39 AM
  #1305
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
My wife's car just says not activated, but it says it about every 8 minutes and kills the music for a few seconds to do it. VERY annoying!
Old 05-16-2019, 11:17 AM
  #1306
bbirdwell's Avatar
'99 and '05 E55 AMG
Via DAS
https://mbworld.org/forums/w211-amg/...g-me-nuts.html
Old 05-16-2019, 11:45 AM
  #1307
Mackhack's Avatar
Its the wrong approach to set Tele Aid to not present when it’s still part of the MOST ring. Tele Aid works with a whole bunch of other control modules and they look for it to be present, active and fully working. This is dealership quality coding. I expect nothing less than that from a moron mechanic and people who have not understood a thing about the system itself and how it works.
There is a specific setting to disable this message while everything else is still working as expected.
The correct steps are explained in WIS but that means one would actually have to get familiar with WIS, look it up and read it.
Old 05-25-2019, 08:03 AM
  #1308
racinwarrior's Avatar
GL63 AMG, E55 AMG, C32 AMG, ML500
Can anybody guide me on how to reset or normalize the steering column height adjustment in star? I replaced the dog bone when the motor was all the way up and the column was all the way down.
Old 05-25-2019, 11:50 AM
  #1309
Mackhack's Avatar
No such thing. Motor knows top and bottom by increased current flow once it reaches the end.
Old 05-25-2019, 12:11 PM
  #1310
BC928's Avatar
2006 E55, Various other German and ‘Murican
Sorry, can you define dogbone? Are you talking about the universal joint for steering before the rack?
Old 05-25-2019, 03:33 PM
  #1311
Mackhack's Avatar
It’s a piece of white rubber that looks like a dog bone or a sand clock which connects the electric motor with the steering rack’s gear box to electrically raise and lower the steering column with the steering wheel on it.
There is a thread on here about the repair when this rubber piece snaps in half. There are also some pictures. Feel free to search for it. It’s quiet enlightening.
Old 05-26-2019, 06:54 AM
  #1312
flax1k's Avatar
E270 CDI
I've changed the instrument cluster with a white dials one, but it's not just a plug&play device.
How can I pair (or code) the new instrument cluster, with the other computers of the car in DAS/Xentry?
I am asking because the milage is not correct, the segments from the cruise cntrl are not shown and I have a speedtronic error on the new instrument cluster display.
Old 05-26-2019, 11:10 AM
  #1313
Mackhack's Avatar
A used cluster is never plug and play. Feel free to PM me if you want me to get it going. Include which cluster, model and model year of your car.
Old 05-28-2019, 03:00 PM
  #1314
The linkage was stuck. had to remove it for the column and turn it by hand to free it. works good now. funny how you can normalize the seat but not the steering column
Old 05-28-2019, 03:35 PM
  #1315
Mackhack's Avatar
Completely different approach of detecting positions.
Old 06-05-2019, 04:21 PM
  #1316
MBWagonNut's Avatar
2005 E500 4matic Wagon
Well, since I keep buying more MBs I guess it's time to get a star setup. I think I have a handle on most of it, but I keep getting hung up on is whether I should be buying a C3 or C4 or C5 or C6 or what. Can someone point me in the direction of the info I need to make this decision? Thanks!
Old 06-05-2019, 04:24 PM
  #1317
Mackhack's Avatar
- Part D is old (unless you only buy MBs up until 2009 it’s all you need)
- SDconnect is all you need
- Xentry Connect was never cloned by anyone. You’ll buy a SDconnect in a Xentry connect case
- Bosch VCI I’m not sure if the Chinese cloned it yet
The following 2 users liked this post by Mackhack:
biker349 (06-05-2019), MBWagonNut (06-07-2019)
Old 06-09-2019, 04:09 PM
  #1318
flax1k's Avatar
E270 CDI
Now I have two speeds on my IC.
The needle of the speedometer shows a different value than the speed displayed in the middle.
Even the units are in km/h, the speed shown in the middle display is mph. The video is a DAS test, but it behaves in the same way when I drive the car.
Example: Speedometer needle = 100km/h --- speed displayed in the middle = 62
Speedometer needle = 260km/h --- speed displayed in the middle = 160
How can I correct this with Xentry/DAS??
Old 06-09-2019, 04:18 PM
  #1319
Mackhack's Avatar
It’s an easy fix. Just keep asking in different forums after I offered my help. Seeing dashes instead of mileage I know you still have a long ways to go. Good luck to you.
Old 06-10-2019, 12:29 PM
  #1320
flax1k's Avatar
E270 CDI
It's not an easy fix as long as nobody give me an answer and I keep asking in different forums because I haven't got an answer yet.
You offered me your help by charging me with $200. That's not help, that's a paid service (and by the way, two of the first errors I solved by myself by studying different forums)
I need people who can share information, not sell them. For example posts #73 or #383 are helpful for those guys who want to change those things.
I hope you got my point ;-)
Old 06-10-2019, 12:31 PM
  #1321
Mackhack's Avatar
No because you violate forum rules and if you would want it fixed properly you would have gotten help. If everyone could do it why don’t you fix it yourself? You must be a socialist or an entitled millennial with an attitude. Never mind. You’re the man. Just keep driving around with dashes in your cluster.
Old 06-12-2019, 12:15 PM
  #1322
drothgeb's Avatar
2005 E55
How did he violate forum rules? Most people come to forums to figure out how to DIY not pay folks a couple hundred bucks to give them answers. You can insult him as much as you want but if you look at the situation (a guy looking for a solution to an issue on an online forum/community) you are certainly the one out of line.
Old 06-12-2019, 12:24 PM
  #1323
Mackhack's Avatar
Shows that nobody reads the rules when they sign up including yourself. Enough said about this.
There is a good reason people don’t just hand over everything for free. It takes time, skills and knowledge. Just because some in this world feel entitled to get everything handed for free, doesn’t mean I have to help him for free. And the amount of clusters I work on shows I’m doing something right.
He’s the one driving around with dashes not me. So figure it out on your own, buy a new cluster or live with it.
Old 06-12-2019, 12:29 PM
  #1324
drothgeb's Avatar
2005 E55
Actually lots of people share information here for free, except for you trying to get $200 to tell this guy what setting to change hahha, loser.
Old 06-12-2019, 12:42 PM
  #1325
Mackhack's Avatar
You’re right... so many creepy, false information on here. But losers like yourself follow them like brainwashed lemmings over the cliff to your death.
If it would only be a setting ROFL
You are the loser by not understanding a thing that’s going on with his cluster. You two should get together. Perfect teammates LOL
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
Quick Reply: Star Diagnostic How To DIY with lots o pics
