Distronic Display help
Old Nov 20, 2009 | 11:09 PM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
My 2005, with the distronic engaged does not give the display with the car and ft..etc on the cluster. It only shows the MPH digital read out as I scroll the menu I don't see this option but the distronic works fine as far I can tell.
Old Nov 21, 2009 | 08:41 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Go Into The Instrument cluster with the SDS to check it....
Old Nov 21, 2009 | 11:07 AM
abhatti55's Avatar
Do I need the STAR with developer mode to check the settings? Also is it possible the car could have lost programming, because the service history shows no repairs being done to the cluster or distronic.
Old Nov 21, 2009 | 01:49 PM
usmankhan355's Avatar
CL63, 997 TT, M3 DCT
when you approach a car in front does it still beep and flash red on the instrument cluster??
Old Nov 21, 2009 | 06:53 PM
abhatti55's Avatar
No, all it does is maintain distance when the cruise control is engaged and the distronic is turned on with the switch next to the shifter, you and the wheel allows you set the distance, but no display on the cluster. STAR pulls no error codes.
Old Nov 22, 2009 | 07:27 AM
very strange- I once had a problem with mine, but the waring lamp was working whereas the distance control was not. At the least I guess you distronic radar is still ok (which are BIG BUCKS) so I suppose showing it to a Main Dealer wouldnt cost too much.. sorry if I wasnt much help.
