Ok Guys i need ur help Im going to the track.
2004 W211 E55K, GL550
Im going to the track on sunday for the last time this season ive gone a few other times and still not sure which way is the best method. Im hoping i can get some help with some of the guys that track there car more often then i do. Here is what i got and u tell me what i should do with it.
1st. Im on my stock wheels with B.F Goodrich g-Force T/A Drag Radial what tire pressure is best for launching?
2nd. My mods are 80mm asp pulley, p.c dyno tune, resinator & secondary cats removed, K&N drop in filters, and johnson 30 pump. car is also star lowered what should i set my susp at? where do i brake torque at? my car is pushing roughly 440 rwhp and torque numbs was around 575 (from what my dyno sheet numbers showed).
Weather should be in the mid 40s to low 50s which is awesome weather. So any help you guys have i can use i have been seeing some awesome 1/4 times and i got a little motivation to lower my personal best which is 11.9**
