No check engine light when SC turns off?
Old Nov 25, 2009 | 01:32 AM
Igor180's Avatar
2006 Granite Grey CLS55
Is it normal that the car doesn't throw a check engine light when the SC turns off? Say you have a faulty IC pump, and those times that the SC turns off after flooring the car for a period of time, shouldn't it throw at least some type of code?
Old Nov 25, 2009 | 05:30 PM
Mamba003's Avatar
2005 E55
I was told by the head tech at Lakeview in LI that it will throw a code. I am not positive he is right. Can someone confirm?
Old Nov 25, 2009 | 05:48 PM
Mikesamg's Avatar
A Prius because I'm green
When mine went out no CEL or warning came on. I was told there is a code but you have to dig for it and it doesn't refer to the pump exactly. I even remember others saying something similar when I researched it on here. The issue would be the dealer not being able to duplicate the SC shutting off just with regular driving and would return the car unfixed, so as I learned from research to pressing the dealer into fixing it and they did. I'd imagine no CEL would come on since the engine is still running fine.
Old Nov 25, 2009 | 08:20 PM
Mamba003's Avatar
2005 E55
Yeah I tried to push him to change to the new IC pump. He did know about problems with the oem pump and mentioned that the new replacement is near bullet proof. In the end he said he cant change it without it being broken and if it was it would throw a code.
Old Nov 25, 2009 | 08:56 PM
cal1's Avatar
SL55, ML500 & Acura TL
No codes when the SC shuts down because of heat, at least nothing obvious like a CEL. My IC pump was nearly dead as far as flow rates and I never got a code. the Merc dealer checked the IC pump flow rates after I complained about extreme loss of power. They confirmed a nearly dead IC pump, but never said a thing about a code having been thrown.
Old Nov 25, 2009 | 09:24 PM
Igor180's Avatar
Well, I had my pump replaced with the MC30, and even got an aftermarket HE (LET). The problem still occurs, it turns off, but then goes back on a minute later. Do you guys think a full coolant flush would solve the issue?
Old Nov 25, 2009 | 09:40 PM
benz_addict's Avatar
V12TT
You might have air lock in your coolant lines. You should bleed the system or yes do a full coolant flush.
Good Luck
