74mm TB shaft grinded to 5mm complement of Exotic_Metal55
Old 01-31-2010, 09:39 PM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
Is a re-tune necessary or can the computer compensate for the extra airflow?
Old 02-11-2010, 12:58 PM
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
any dyno results?
Old 02-11-2010, 02:39 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
After doing any engine mod you can benefit from a retune.
Old 02-11-2010, 02:42 PM
shardul's Avatar
Originally Posted by NEMES1S
any dyno results?
See post 21
Old 02-11-2010, 07:54 PM
BlackCard's Avatar
CLS55 AMG
Originally Posted by 320 dreamer
if your talking about enlarging the body of the t/b maxbore does this. they can bore the 74 body to 77 mm and install a new butterfly and gasket match for 125$ shipped. if your talking about grinding the butterfly to a knife edge many on the srt-6 forum do this to the leading edge to improve airflow.
remember grinding the shaft down may weaken the mounting points. allowing it to crack and break. dont go to far!!
Anyone used maxbore service?
Old 02-11-2010, 09:13 PM
320 dreamer's Avatar
2003 porsche 996 turbo
bulldogger from the srt-6 forum has used them and as soon as i know eurocharged will be back in atl to retune ill be sending mine down there. very informative website check it out
Old 02-11-2010, 11:29 PM
  #32
NEMES1S's Avatar
Originally Posted by shardul
See post 21
I did see that post, but it is listed as it combined with another mod, I was curious if there were any dynos with only this mod as the variable
Old 02-12-2010, 01:24 PM
  #33
TopGun32's Avatar
would be nice if we can find a shop here in cali that would do this mod..
probably $150 job... 3hrs at $50/hr
I'm looking to upgrade TB or shorty headers.. but i'm not sure what would be best approach.
headers would lower boost and would make power...
TB would increase air flow, but current exhaust manifolds are probably getting to their limit with a stage 1 car.
So... probably grinding the TB and getting headers would be ideal for me.
Old 02-12-2010, 01:29 PM
  #34
AMS Performance's Avatar
AMG
Just take out the front half shaft and leave the back one and use some upgraded screws with larger head to hold the plate in place, that will gives you all the flow you need. Don't touch the back half of the shaft, you need those threads.
Old 02-12-2010, 01:31 PM
  #35
AMG
usually up to 8-10% increase in area the ECU can adapt (especially our benz ECUs), but anything over that and you will need to reprogram ECU. This mod should be less than that threshold so it should be ok.
Old 05-28-2010, 12:20 AM
  #36
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
So now after a few months, curious how this mod is holding up? Shaft broken ,bent, HP, etc? Thanks
Old 05-28-2010, 03:21 AM
  #37
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
still an awesome mod -- I have a check engine light thou -- but you can do this nearly free mod and get about half the gains that the peps with 82mm TBs are getting -- and seems like those big TB are not flawless: huge price tag and having ECU problems
Old 05-28-2010, 03:22 AM
  #38
pearlpower's Avatar
CEL due to the grinded TB? That sucks but thanks for posting.
Old 05-28-2010, 12:06 PM
  #39
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Nice mod and one to consider - I think we can do allot more at the air filter side ... no one really gone to town here yet ... think thats the next restriction in the chain.
Old 05-28-2010, 03:15 PM
  #40
yup- it really sucks but our ECUs are extremely sensitive and mine is throwing a CEL - not a big deal I guess-- only a light - i still have my added performance.
Old 05-28-2010, 11:40 PM
  #41
GT40MkI's Avatar
2005 E55 / 2001 e39 M5
What code are you getting?
Old 05-28-2010, 11:42 PM
  #42
AWOL's Avatar
e55
yeah, I wonder why it would throw a code?
Old 05-29-2010, 01:06 AM
  #43
Earlier I was getting alot of codes -- I believe it was because I also grinded down the blade to a finer edge -- I have since replaced the blade with another stock one -- still getting a light but not certain it is the same code(s) -- I will need to get it checked later, when i feel like running to autozone.
I also bored out the TB itself a little -- but i kept the diameter the same at the blade's idle position ---So, there should not be any additional airflow through the blade at idle -
this is all theory -- evidently I underestimated the ultra-sensitive ECU
lastly - my TB could have some bad pins in the harness
Old 05-29-2010, 01:15 AM
  #44
pearlpower's Avatar
Well, as you did a few things beyond the standard grind, it's up in the air as to what really is causing the CEL. Please keep us posted.
Old 05-29-2010, 03:02 PM
  #45
very true -- i would do it again if i could -- So, i am pretty satisfied with the results -- my friend will try my TB on his car to see if he likes it -- I am sure he will be making the same mod, shortly after he gets a test-run
Old 05-31-2010, 11:58 AM
  #46
NEMES1S's Avatar
Anyone have a guess as to how big of a pain it would be to pull an sl600 tb out to do this?
Old 05-31-2010, 02:18 PM
  #47
my check engine light is odd -- one week it is there and maybe one day its off - i will recheck the pins and harness later
Old 09-18-2010, 09:23 PM
  #48
07g55's Avatar
G55 - R500
putting a thinner butterfly would be great. Also wondering if rounding on of the edges would help.
I think maxbore ports the entire TB housing, but that would probably only make sense if you can also port the plenum. Was thinking about having maxbore doing a stock TB for me, would love to see how thin the butterfly is he is using. On the website he says that it will get replaced
Old 09-18-2010, 09:58 PM
  #49
i thinned my blade but it threw too many codes -- i swapped it out for another stock blade-- its running pretty decent now ---- I only get problems when the car idles tooo long... i think my idle needsto be bumped up -- its around 600 but goes down to 550 sometimes ---- should be at 700.
Old 09-18-2010, 11:49 PM
  #50
sneakyneon's Avatar
Bicycle
Max bore dose replace the TB blade with a thinner one but he use's the stock shaft so there is a mix maxed set up with gaps were the blade is screwed down, No very impressed with the work he did on my 82mm tb.
Quick Reply: 74mm TB shaft grinded to 5mm complement of Exotic_Metal55
