Airmatic Droop
Old Nov 27, 2009 | 06:31 PM
Shadow5501's Avatar
Car free at the moment
Airmatic Droop
The driver's side rear corner of my '06 goes down about an inch overnight. After 24 hours it's sitting on the bump stops. Pops right back up when using the car, though. How much airmatic drop is acceptable?
Has anyone had difficulty getting MB to replace/repair airmatic under CPO warranty?
Your comments appreciated. Thanks.
Old Nov 28, 2009 | 12:33 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Shadow, you may be on borrowed time. When the air matic fails the car may not be able to be moved (flat-bed tow). Your air matic should hold your car up for months, if you have a slow leak the air pump and relay may burn up due to extended duty cycle to over come leak all the time. If under warranty get it to dealer ASAP. Don't be stranded.
Old Nov 28, 2009 | 12:36 AM
RacerX0911's Avatar
usually they will fail soon after...
Old Nov 28, 2009 | 03:13 AM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
If it's dropping like that, it's leaking. And the pump will try to pump it up to keep it up after you start the car. As you drive and depending on where the leaks is, it might stay up. But the pump is working overtime to keep it up. And the leak can get worse until it finally stays dropped.
It's covered under the CPO and you just need to convince the dealer that it's leaking enough and get the strut replaced before the pump burns out (as Yacht Master said.)
Old Nov 28, 2009 | 07:36 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
My 07 E63 had this same exact problem, but it was my drivers rear strut that was failing. I talked to my shop forman, he said that there is a problem. The car should level out, and never bottom out, or completely deflate. They replaced mine with no problem, they hook it up to a computer that reads the faults from the suspension. So, please get your replaced before it completely fails on you, leaving you stranded somewhere.
