Meth Inj
where did you put the nozzle?
A couple of questions come to mind if you care to answer. First, did you figure out a way to pull fuel to compensate, or are you injecting mostly water/washer fluid? What size nozzle did you try?
-lowpro
do you think with the nozzle mounted on one sided there is slightly uneven distribution between left and right banks?
on a 60 degree night from 0 to 130mph my IATs go to 125 with ICE packed in my 9gallon reservoir.
-lowpro
My set up is very basic with no frills, they have all sorts of cool stuff but I believe in the kiss method: keep it simple stupid.
i think sneaky's logs def prove that as expected w/m does work on our car (just like all others)
keeping IATs under 80 on a full 1/4 mile run is amazing.
what does your car run sneaky?
I haven't raced the car with the meth yet since the tracks are closed for the next 3 months. but on my old set up it ran a best of 11.84@117 but that run was a fluke, The last time out it was running 12.00@119. basic mods at that time were a pulley headers, 3inch exh. with NO tune. this year it has a 82 TB pulley, headers no cats, 3in exh, phernolic spacers (top and bottom)some port work, water meth injection and fingers cross i can get my tune.
I would be interested in your results running water only and water / meth...?!?!?
