Did some strange today (better ET)
PLATINUM SPONSOR
Well, H town was snowed out and all tracks closed.. Got up and drove 2.5 hours in the ice to a new (strange) track for me.. It is in the hills near San Antonio Texas and is 600 feet above sea level..
Made a bunch of passes but could not hook on this track .. It is an NHRA track but only 20 cars showed up to race all day for test tune and bracket racing![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
None of my 60 ft were better than my street tire runs , of the past.. Car would grab and then break loose or just break loose..
Best ET was 11.53@122.62mph with a spin 60 ft time of 1.794.. Tried pressure from 23-16 PSI but lower PSI was hard to warm tires and would bog on S/C down in the burn out area.. Ideas???
Checked IAT`s and engine temp on the way. Ambient was 38-42 deg. on the way, IAT`s only 48-52..lol The engine temp is staying to cold now at 156 to 162 deg. on hwy speeds.. With low IAT`s and cold engine, the motor can stumble, when boost is applied at that cold temps. I feel the cold IAT`s are a must but need engine to run warmer for best perfrormance..
Track was supposed to stay open but they ran us off 4 hours early, as it must have been costing them money to stay open..
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Chevy Camaro
Not bad times for running at SAR. Track prep allways sucks at the track if there are no big events. Since there no one there and no big horsepower cars to lay down some rubber. You might have hooked off the line but ended up spinning 30' down track.
Good to see you picked up some MPH. But if Houston will ever get some decent weather when HRP is open you should be turning out some low 11 ET and some 124-126mph.
Track was supposed to stay open but they ran us off 4 hours early, as it must have been costing them money to stay open..![bs](https://mbworld.org/forums/images/smilies/bs.gif)
You are consistant and you learn each time out. Sounds like this track could be great for a private rental with some extra cah for prep.
Thanks for posting the slips,
PLATINUM SPONSOR
what car was next to you running the 12.04@118? do you remember looks like that was a hell of a close race.
Would be a nice track to rent but hate giving up the 600 ft above sea level..
A new GTR was only allowed to run 8th mile and he had a 7.00 @ 100 mph in the 8th!! No traction issues for all wheel drive..
