Green Horn needs help
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Your going to need a 3/8" ratchet, to insert into the belt tensioner. To take up the slack tension on the belt tensioner so that you can remove it. Follow the belt routing diagram under your hood.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Let me help you out here. This thread is for the W211 2003-2009 E class AMG.
The thread that will have the information for your E 430 is the W210 E class.
https://mbworld.org/forums/e-class-w210-2/
Here is a post that will help with your belt change out. (post 7)
https://mbworld.org/forums/e-class-w...eing-belt.html
