MY 2011 Twin Turbo!!! for v6 and v8's :
#101
i ran 11.71 stage 1 on 19" street tires with a 1.86 60'. out of all people you know what adding a drag radial would have done to the et on that setup
What did you trap as a stage 1 E55?
i am no longer stage, but i am nowhere near stg5 lol
correction: stock powered e55 and stock powered cls63. sorry but running on drag radial is not STOCK and is a significant mod
I never said I was stock
what I am saying is a stock CLS 63 vs a stock CLS 55 would be equal
most would agree with me that stock is the way your car rolled off the factory. it is common sense that stock your car will not go 1.4x 60' (which btw is awesome)
agree with you 100%
also i was talking about ETs not trap speeds. record e55 et is 11.77 while record e63 et 11.95 and yours is 12.00 . thats a fact
Trap is a better indication of HP, so lets use trap it is a clearer picture.
LOL i never said a stage one car will embarrass you. I also said that the race would be driver determined.
Full throttless did
However just about all Stage 1 cars have a faster ET then a 11.80. No point to argue of that. My car did in 11.7, tracshun went 11.5 stage 1 and there are plenty of ppl in between.
agree with you 100%
Full throttless did
I respect you and your responses,
#103
2008 A8L, 2002 996TT X50, 2009 X5
Really? If they produce the same times, why do so many people bother with a dedicated drag setup with DRs? That seems counterintuitive. I thought "most" guys (63 or otherwise) can lower their 60's and shave a couple tenths' worth of ET by using DRs (like M/T or Hoosier) instead of street tires (T1Rs, PS2s, Invos, et al).
#105
E63 P30, CL500 Sport
1) ECU Tune
2) Weight reduction (includes wheels - this one is the most important for the 63)
3) Sensor relocation.
The rest of his amazing times come from driver skill/experience (a lot of people under-estimate this), properly trained tranny (not just a reset), good track conditions, good weather conditions, etc...
#106
#107
The 11.77 E55 was on street tires as was the 11.95 E63
as was the 12.1 E63
All the best times on stock cars are absent drag radials
#109
997TT, R8 V10+, G550, Plaid S
lets use cars same day same track for our comparisons not times from cars all over the usa
What did you trap as a stage 1 E55? -121.8
i wasn't arguing that.
trap is a better indication of HP. but i was not comparing HP. i was comparing how fast the cars can cover same amount of distance....
Full throttless did
lol you and MB Forever are arguing with me like i was trashing the 63s. which i wasn't. i simply stated that a stage 1 e55 should be faster then 11.8 in normal conditions. not cls55 - because i don't know what those run, so i can't say much about them.
Full throttless did
#114
E63, S550
NOT on a stock E63.... I've ran side by side with another stock E63 countless times (username: gE63). He was running drag radials and I was running Continentals (stock tires), and his 60 foot was identical to mine. We switched drivers, cars, and tried a few other things. At the end of the session he did edge me out a little but not by much. For some reason, the 7g tranny bogs if you grip too good. This is still a mystery to me, as I'm trying to get to the bottom of it, but I do believe that once we figure out what exactly is happening with the 63 launch, drag radials will benefit us a great deal
#116
Correct..... the torque becomes noticeable right after 4500 rpm. However, on modded 63s, the torque arives a little earlier: 2.7k to 3k, which then would make drag radials more beneficial
#119
The Quickest Stock Powered E55 on DR's on the West Coast 11.79" - what was HD's best ET on street tires? 11.9 or so?
MB Forever - that does make some sense, for stock cars. Although, the 6.2L V8 makes plenty of TQ down low compared to the M112k (just saying, everything's relative ). Question - how much does the 7G let you preload the TC and raise the rpms before you start pushing through the beams? If high enough to spin a set of street tires - it would seem (hypothetically) that a properly heated set of DRs could yield a better 60' and ET... no?
#120
Our cars look identical, so...
Just run your beautiful CLS, beat my splits and I will STFU. Until you do your just a keyboard striker.
Your M113 is a super power plant as is the M156. We have already seen with the advent of the M159 the 6.2L V8 can achieve near 600 hp. STOCK
We are getting greener not meaner.
#121
MB Forever, as usual, very interesting info - thanks for sharing. While I agree 100% that same day, same track comparisons are best - I'd caution against drawing any definitive conclusions from a sample size of "one vs. one." To be clear - I don't have any beef with anyone in this or any other thread - but for someone to state "most 63 guys" (no mention of stock or modded) and then someone else reference one applicable, relevant heads-up result of two cars... while that may reinforce the hypothesis, it falls far short of confirming it (IMHO).
#123
I wouldn't call it intensively, but we have tried it on at least 4 different cars. And even more interesting..... results were a little better on lighter stock 63 models, aka, C63 and CLK63. I'm thinking that because of the nature of the 63 design, weight causes spikes in torque management interference at a much higher rate than it does on the 55..... but again, at this point, these are just observations. I wish some of the aftermarket companies would do more research on this.
#124
are you guys using the same exact overall height tire on the 63? i read that newer cars act up if they sense gear ratio changing which can be caused by changing the overall diameter of the tire. i know the e55 monitors this too but it is a 5spd with much longer gears then the 7spd. maybe thats part of the issue.
#125
That was my car. Sold it to another member this summer. Mystery solved.
