GUIDE: Installing Factory Comand Navigation (with pics)
When I bought my new non Navi E500 back in 05, I had the dealer install Navi as part of the deal. They balked at first, citing costs, but ended up doing it to get the sale. I drove the car for a week or so without the Navi, and it was a huge enhancement after it was done. It took them 2 days to get the car back to me, with appointment, I now see why.
I have an 03 e500 - All my wires were already there.
I have read on countless threads that 04 1/2 and UP need to route wires
Im the lucky one. Everything was on my side and my NAV was plug and play
Of all the parts listed all I dont see is the splitter.
I have an 03 e500 Sport with the sh*tty tape deck.
I had a friend who totaled his car- he let me take his Command Unit,.
I took the Head Unit and Nav Unit.
Everything was plug and play. My car had the wiring in the rear for
the NAV unit and only worked when both were plugged in (front and back)
Stereo works everything works BUT the NAV.
There is ONE black wire that has an antenna line feel to it.
Its coming from the cars internal wiring in the trunk, it jumps off the
NAV units power and lead wires.
That is the only UNPLUGGED wire in the rear section. However there is
nowhere I can find for it to plug into. There is a similar wire that comes from the
front of the car to the back and then right behind trunk hinge on the driver side
it leads up and appears to route up to my cars snubby antenna.
Is this why my NAV doesnt work? I feels as if its my antenna for NAV?
NAV worked in the car I took it from right before I took it out.
***** AFTER READING YOUR AWESOME POST
I did unplug the antenna cable and instantly the Tele Aid flashed on my cluster.
That being said, does it seem like all I need is the splitter to make my NAV work?
I have a full functioning head unit, radio cdc and cd and mp3 and DVD audio all working.
I just did the software update on the head unit. Only the single drive in my head unit
has all the new updates. CD changer only plays regular CDs.
ps - Where can I find the NAV software update?
pps - How or what do I need to install XM Sat Radio? Does that jump off my AUX or Can I really Have
CD, CDC, FM, AUX & SAT?? Really is MBZ this effing Awesome?
You can get an iPad, an application like REV or Dashcommand, and hook it up with a wifi system like KIWI WIFI to your OBDCII...
Plus movies, maps, Music, etc.
There are many youtubes showing it.
I have a faulty navi DVD unit on my -04 E320cdi wagon and I found one that might work with the part# A2208206085004.
My own DVD has the part# A2208206085005 though, do anyone of you know if these two are interchangeable? They are the same 6059 models but they do have a few different markings:
A2208206085004
6059K EC:124 mfg.date 48/03 Q04
A2208206085005
6059H EC:134 mfg.date 34/04 Q05
I'm in the process of retrofitting my 06 SLK. I've cobbled together most of the parts. I'm converting from Audio 20 to Comand, so have to add an AGW. I'm stuck on one point. I read posts about making sure I got a twin tuner AGW. I think I did; and it has 2 antenna connections. Both FAKRA, one yellow, one dark blue/black. In a document I found, the yellow one is labeled "Connection plug IF connection". What is this and what/where is the antenna that feeds this plug?
Thanks,
Brent
I'm confused about the radio antenna. The rod antenna on the car currently connects to the Audio 20 head unit. Audio 20 is a single unit containing radio tuners and amplifier. With Comand, the head unit is just a display (and CD player). The AGW (audio gateway) contains the radio tuners and amplifier. The AGW has 2 FAKRA antenna jacks; one yellow, one black. I don't understand the purpose of, or how to feed the 2 FAKRA jacks.
I'm installing NAV drive to my W211, I don't have Tele Aid, do I need antenna splitter then? Thank you!
Btw I'm from Europe, my Comand has green FAKRA connector on the back, but no TV option, and obviously no Navigation, also no HK audio system and no Tele Aid and Phone integration.
Also would really like to update everything to the latest SW version and have the 2016 maps as well. My headunit SW version is 10.270, not sure what my nav unit SW version is as I haven't finished hooking it up yet. I've seen several discs for sale on eBay but I would appreciate some direction before I buy anything. Thanks!!
Last edited by charlesb2003; Feb 4, 2020 at 07:00 AM. Reason: needed to ask more questions
Here are some pics of what I received:
This bracket is for the Parktronic control module I think, you need this one: A2115455440, as for the side panel, I don't know where to buy them as my car already has correct side panel.
Please go again to Engineering menu and write me SW Ver. HU then I will know which version you have.
You can download maps from internet for free and burn it on DVD, but if you are below V12 then you will first have to download V12 and then from V12 to whichever version you want.
You have this bracket
This is how it looks when everything is done
DONE!
