Bluetooth question
Old Dec 21, 2009 | 06:17 PM
izzynyc's Avatar
2016 C63s
Bluetooth question
I just found out I have a connector plate in my arm rest. What do I need to get bluetooth working in my car? Your help is much appreciated.
Old Dec 21, 2009 | 08:39 PM
Martinsvi's Avatar
2006 C55 AMG, 2010 Genesis Coupe
If the car was wired and fitted with the phone option and the connector plate would be a good clue that it is there then all you would b\need is the bluetooth dongle that snaps onto the connector. The latest one supports alot more phones than the old one did.
Old Dec 21, 2009 | 10:48 PM
izzynyc's Avatar
2016 C63s
Thanks Martinsvi. So I would just need the module.
Old Dec 21, 2009 | 11:03 PM
Martinsvi's Avatar
Yes, if the car was set up for a motorola v60 or such from the factory.. My car was prewired for the phone but did not have the phone interface or the connector in the arm rest. I had to add all of it to get the bluetooth installed. I would have been as well served to have purchased a mobridge bluetooth module and would have got the ipod adapter with it all together. After I had purchased the phone I/F, the bluetooth module and the ipod I/F. It would have been less money and easier to install.
You will probably just need the module fot the armrest though. If you have any doubts call this guy. He helped me with my factory refit for the phone and bluetooth.
Keith Valentine
714-746-5930
Old Dec 21, 2009 | 11:19 PM
MACBOOKUSER's Avatar
tek
as long as you have an actual connector in the armrest, then all you need is the bluetooth adaptor-plugs right into the conector in the armrest and your good to go-might need some codings-all cars are different-plug it in first and see if it works- i believe that it will though
Old Dec 22, 2009 | 09:20 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Just go to Mercedes benz Dealer, and tell them you need a bluetooth interface module.
The modeule will connect your phone to the car using bluetooth technology, it support numerous types of phones. Check out this link; http://www.wireless4mb.com/ This has all the information that you need to get started.
Old Dec 22, 2009 | 09:40 AM
vyper340's Avatar
E63 AMG
I'm a noob so I apologize if this is covered somewhere... Does the 2008 E63 have the phone interface so the only thing needed to buy is the BT module? I did not see the option list include anything as the one I am purchasing has every option except voice control, partronic, distronic.
Old Dec 22, 2009 | 09:49 AM
Yuille36's Avatar
Look inside your center console, towards the back. There should be a black plastic guard, remove that, and there is your adpater interface. If you have that, the only issue is buying your Bluetooth interface module from Mercedes Benz. Look at my previous post and lick on the link, that link contains the information you seek, and will answer any further questions you might have.
Old Dec 22, 2009 | 09:56 AM
vyper340's Avatar
E63 AMG
THANKS!
Old Dec 22, 2009 | 10:36 AM
izzynyc's Avatar
2016 C63s
Thanks for all the info guys.
