Old 06-10-2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Battery keeps dying!!
Old 01-25-2022, 05:08 PM
  #76
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by YankTar
Which box is the N93/1? The upper looks like a power amplifier.
I already have issues leading me to want to get rid of the car.
BTW, the Driver DCM module I got off eBay seems to work perfectly but I still don't have power door locks or remote trunk opening.
The lower more shiny metal box in the picture is it. A session with MB Star would likely point you in the right direction on those locks.
Old 01-25-2022, 05:35 PM
  #77
YankTar's Avatar
2003 S5004matic (220)
Thank you!
MB Star???
Old 01-25-2022, 08:26 PM
  #78
machild's Avatar
Thank you!
MB Star???
Star is the computer diagnostic tool used by MB. It can do about 1,000% more than a typical fault scan tool. It can look into every control module and do bi-directional control of its functions to confirm what is working and not. If it reports a certain sensor is not working properly (just as an example) it will not only indentify that specific sensor but a picture (similar as I posted for N93/1) and where it is located in the car. It also provides specific tests to confirm if the suspected reported issue is, in fact, at fault. It is the best way to work on a MB.
Old 01-25-2022, 08:53 PM
  #79
YankTar's Avatar
Wow! Thanks! It's also depressing because I really don't want to sink thousands of bucks into a car that's book value is, at most, $4500--and that's pushing it.
Old 01-25-2022, 09:06 PM
  #80
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
My W211 2003 E500 had similar problems with the battery dying every two days and it ended up being the power seat modules. My indy mechanic bypassed the circuit and soldered some wires together to avoid having to replace the modules. The power seats still worked but only with the ignition on.
jaguarmanuk (02-07-2022)
Old 01-25-2022, 10:35 PM
  #81
YankTar's Avatar
Interesting possibility. I've been "hearing hoofbeats and not anticipating a zebra" but the cause may well be a "zebra" and not a "horse".
Old 01-26-2022, 10:01 AM
  #82
machild's Avatar
Exactly - doing a deep scan with Star will likely get you going in the correct direction. Then you decide what needs to be done and not be guessing. Nothing is straight up with these highly intergrated networked cars.
Old 01-26-2022, 12:13 PM
  #83
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
on my personal car...the bluetooth module will stay lit and active as long as its close enough to continue being connected to my phone after exiting and locking vehicle. when the bluetooth module is active, it keeps the audio system active as well.
not sure if this is faulty or by design.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 01-26-2022, 12:28 PM
  #84
YankTar's Avatar
Pretty sure it's by design. My S500 is so old we originally had to buy a special phone to work with the electronics. When it aged out, M-B sold the V60 adapter that plugged into the phone slot and provided rudimentary Blue Tooth
Old 02-07-2022, 02:59 PM
  #85
jaguarmanuk's Avatar
ml320
I watched a video on Youtube that detailed this and it solved his problem. My problem is that the rear suspension goes down in spite of a new compressor and a new battery.
Old 02-07-2022, 04:55 PM
  #86
YankTar's Avatar
That almost certainly means that there's either a leak in the rear suspension, or there's a problem with the rear suspension as well. Is OK once it's pumped up and you're driving?
I actually have the V60 adapter--I think I have 2 of them. Also the adapter for the SL55 AMG which is a little different. Been sitting in a drawer for many years now.
Old 02-10-2022, 02:05 PM
  #87
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
It is most likely a leaking rear air bags, most often when your rear air bags age, they develop tiny cracks in the rubber, and that is where the air is seeping out.
Or, it can be the air distribution block that is leaking, but you can spray soapy water and see if bubbles develop.
Most people just replace the air compressor, front air-struts and rear air bags, and they neglect to change out the air distribution block.
Quick Reply: Battery keeps dying!!
