VRP 175 & 190mm Pulley
Did anyone ever pick up any of these pulleys and if so what were the results? I'm talking about the upgraded design.
I'm more interested in the 175 to see if anyone has had some great results from this pulley. I also now that it was design to have the outer ring come off and the 190 put on if the 175 didn't fit your needs.
I'm not sure but if ASP can make a pulley larger than the 180 simply by requesting one and Ali says that people in Abu Dabi have been running the 190 for the past two years it must work ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
IF anything most seem to be happy with ASP
997TT, R8 V10+, G550, Plaid S
2009 c63, 2011 GT500
am from abudhabi and i had 650hp 2006 E55 it was tuned by evotech everything was perfect except the pulleys i had to change them every 5000Km...
E55, Supercharged Z4 (sold)
Exotic metal seems to be pretty up on pulley info. Maybe he'll chime in. From what I understand the ASP design is ideal because it keeps the factory damper and doesn't have the problem of being out of round due to torqueing (sp?) down the bolts and having that move the outer ring. It only needs to be out by a small fraction.
I am thinking about the asp 180 as well. I've had three LET pullies grenade on me. The second time cost me two grand out of pocket (woodruff key broke). I need something reliable. Any and all recommendation will be greatly appreciated.
Silly question as I'm considering the Eurocharged Pulleys of 172 and 180. What exactly is the difference? May I assume the larger the pulley's the more boost? If so what is the range to expect? So for example:
172 = +50HP
180 = +75
190= +125?
Perhaps there is even a formula?
Thanks.
Alex
172 = +50HP
180 = +75
190= +125?
Thanks.
Alex
PLATINUM SPONSOR
The VRP I had tested also used a stock dampner. The general design was good but the building of the part was not done correctly.. The part was not balanced and the design did not allow for proper centering of the bolt on outer ring. This is why so many people have "wobblers" from them.. I have seen 4 VRP`s on cars and they all wobble. I have only seen 4 VRP`s ever and only had one tested, so do not know if they changed the design or improved the building of them.. I would be very cautious or have them checked for proper balance before installing on my 48K motor.. IMO.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
E63 P30, CL500 Sport
But how would one get a VRP pulley anyways? I thought Victor was banned due to some conflict with the site and Vadim started his own company (Fedor Dezyns)
I wouldn't chance it with an unproven product. If any company released a pulley, or any other item, which then proved to be faulty, why would you think the 2nd gen is any better? Unfortunately, we can't just tear the motor down and check the main bearings.
Perhaps if you performed a routine oil analysis, additional bearing wear could be detected.
PLATINUM SPONSOR
There was actually a recall on those pulleys and VRP changed them free of charge (at least to most of the people that I know who had one).
But how would one get a VRP pulley anyways? I thought Victor was banned due to some conflict with the site and Vadim started his own company (Fedor Dezyns)![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I am sure there are other good pulley`s out there but ASP has never given me a problem on any of my 8-12 vehicles I have used them on. Good old American made and 22 years at it..
I am going larger than 180mm and that will be a new topic someday..
That is good to hear but the one I had tested was only purchased a couple of months ago and brand new. Then again, it may have been old invnetory on a shelf..
I am sure there are other good pulley`s out there but ASP has never given me a problem on any of my 8-12 vehicles I have used them on. Good old American made and 22 years it at..
The PO asked me to chime in VIA PM, so that is my 2cents on it..
PLATINUM SPONSOR
E55 w/ goods, Z32 Project underway
If its the one from Ebay, it looks awfully like the one I had that wobbled, removed and sold. Good luck to whomever bought that 'new' pulley off Ebay.
