Radiator - is it normal for the anti-freeze to decrease?
Old Jan 18, 2010 | 04:50 PM
rondocap's Avatar
Mercedes S55 AMG
So I put some Mercedes Anti-freeze about 2 weeks ago, and it was filled to the top. (To the rubber lining where it is recommended.)
I opened up the radiator cap to check where the level was, and it had gone down about half an inch or so.
Is this normal? Does some of it evaporate? I see some white residue on my radiator tank area too. It's been very cold lately, so I am not sure if that causes it to act differently.
Or do I possibly have a minor leak?
Old Jan 18, 2010 | 05:51 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
common problem on 03 cars - coolant leaks into transmission fluid system, because the transmission fluid is cooled via the radiator.
https://mbworld.org/forums/w211-amg/...s-lines-2.html
Old Jan 19, 2010 | 03:21 PM
£ C43 £ AMG £'s Avatar
E55K AMG
+1
catch this problem early before you need a gearbox rebuild. Coolant fluid level dropping is not ok.
your SIG says 2001 model, is the car an S55 kompressor?
Old Jan 19, 2010 | 03:37 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Coolant is a sealed system - in theory, the level should never change unless you have a leak or the problem mentioned above.
Old Jan 19, 2010 | 05:00 PM
rondocap's Avatar
Mercedes S55 AMG
It's not the kompressor engine, the 55 Naturally Aspired one.
I asked a mechanic today, and he said it could just be normal due to the temperature change - the level of the fluid can fluctuate a little bit if the car is warm or cold. Does that make sense?
Old Jan 19, 2010 | 05:35 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
I thought the same thing (temp change) on my Z4 and it turned out to be a leak in a reservoir. Best thing to do is get under it somehow and take a look.
Old Jan 19, 2010 | 10:01 PM
E55AMGGG04's Avatar
04 w211 E55
When I installed my CM30 pump it had a little crack and it was leaking. I tried sealing it but I have my coolant light showing now. I saw the drip when I installed it and after sealing it stopped. I dont remember what I used to seal it ..
