Anybody thought about a bigger blower?
"Has anyone tried to fit a bigger blower on the 55 engine?"
I said I have done a ton of reading here and never came across any info. Of course a search was no help. I have seen some mention of porting the stocker, but only briefly in one or two threads.
I know it would require some relatively involved modifications to get an off the shelf unit to work, but has anyone even tried?
Just curious if anyone has even tried to line up a Whipple or Kenne Bell or shiits and gigs????
This is like the first mod the domestic guys go for when they want big power. I have seen plenty of cars with cams and head work, which cost like $8k minimum, and would think a bigger blower would make those mods pale in comparison.
Street King, are you listening....
My question really is has anyone taken this idea beyond the conjecture stage?
Yes we would need some type of clutch for the supercharger. While I haven't given one hint of a thought to how we would accomplish that, I assumed it would be required for proper operation of the ecu.
Outside of fitment and minor tuning what other stumbling blocks would there be?
Anyway, I hope you guys don't mind me asking a few questions because I'm trying to learn more about this engine.
Also, do you know what the ECU is looking for while cruising to determine if there's boost present? The BMW 135/335/535 have similar boost requirements, but they were actually pretty easy to get around once we knew what the computer was looking for. We just fed the computer the voltage it expected to see from the MAP sensor and it was happy
Also, do you know, has anyone tried using a piggyback controller to add/remove fuel and timing as necessary where flashes have failed?
It sounds to me like stuff like this has been tried, and ultimately failed, but I can't find any info on the web. I'd love to read any links, or whatever info you can direct me to so I can see what's been done. Are there any projects you guys remember that I should try to dig up? Thanks!
Yesss...
