Akebono ceramic pad install (nice!)
If that pic dies for some reason, it is showing that I still have most of the pad remaining. I have had ZERO problems with these pads. They work great and create practically NO brake dust and I have never had so much as a peep come from the brakes. When the time comes, I will be running these again.
Public Service Announcement: Please stop calling them "break pads". I see it all over the internet. Drives me crazy.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
E55 Akebono EUR983 EURO Ultra-Premium Ceramic Front Brake Pad Set $131
E55 Akebono EUR984 EURO Ultra-Premium Ceramic Rear Brake Pad Set $99
I concur, I had the EUR983s on the front and the difference is NIGHT AND DAY when it comes to dust
Pros: No brake dust, no fade from high speed stops. None at all.
Cons: Less initial bite than factory pads but grip hard with a little heat. However, only with MB. The BMW seems un affected and has good bite immediately.
