Dynamometer for E55 AMG
Old Feb 7, 2010 | 05:21 PM
rizampi's Avatar
w211 e55 amg
Question Dynamometer for E55 AMG
Hello everyone,
an important question: to do a test on the dynamometer, I put the car in "dyno mode" or just disable ESP, M mode and 4 gear?
Thanks from Italy
Old Feb 7, 2010 | 05:39 PM
BenzoBoi's Avatar
Super Moderator
W221
You need to do be in dyno mode when you test your car on the dyno. M and 4th gear is correct.
Old Feb 7, 2010 | 11:15 PM
AWOL's Avatar
e55
some prefer 3rd gear pulls
Old Feb 7, 2010 | 11:33 PM
cahiil55k's Avatar
Dyno mode, shift mode in 'M'. I believe in 4th gear you'll be going over 160mph on the dyno. I prefer to play it safe and request 3rd gear pulls. The numbers supposedly come out lower in 3rd gear but that's fine with me.
If your car is like mine, it will downshift even in M mode because of the kick down button behind the gas pedal. You can block the button but that kills 3/16" of pedal travel, so we end up just gathering data from 3500rpm - 6500rpm. Others have gotten around this problem either with a steady foot or some other technique - hopefully this won't be an issue for you.
Old Feb 8, 2010 | 11:58 AM
rizampi's Avatar
w211 e55 amg
Thanks to all, but why set the machine in DYNO mode? Not enough to turn off ESP?
Quali sono i problemi senza DYNO MODE?
Riccardo
Old Feb 8, 2010 | 11:55 PM
cahiil55k's Avatar
Riccardo
Why not? It takes 30 seconds to activate dyno mode and 10 seconds to shut off. There's alot of existing posts about the benefits of having dyno mode on so check those out too.
Old Feb 9, 2010 | 09:13 AM
rizampi's Avatar
w211 e55 amg
Ok, many thanks to all!
Old Feb 9, 2010 | 04:54 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Car will sense wheel spin rear and no motion in front. Triggers ESP whether you have it disabled or not. Sounds weird but it's just the way they designed the 55's.
Just pop her in dyno.
