Need 06E55 oil cooler ????
PLATINUM SPONSOR
Anyone know where I can get a used 06 E55 oil cooler right away?
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Give www.parts.com a call, and see if they can help you out. I suspect that the dealer wants a butt load of money for one?
PLATINUM SPONSOR
99DirtybirdWS6 Could you put a universal one in front of the radiator?
__________________
www.ultimatepd.com
www.ultimatepd.com
