Jacking points E63
Old Feb 6, 2010 | 05:49 PM
hgerhardt's Avatar
E63
Jacking points E63
I've looked at many archived posts and can't find an answer: is it safe to lift a W211 E63 under the rear diff finned aluminum heat sink? Put a block of 2x4 under there first? It looks like a pretty stout casting and should hold up OK.
Old Feb 7, 2010 | 08:25 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
NO, absolutely not!!! It is aluminum, and will break off under the weight of the car. If you have to lift the rear diff, then place a 2x4 under the differential, but not under the cooling fins. I'm glad that, I seen this thread before you made a mistake. The cooling fins can't handle the weight of the car, and the bolt might shear off, ruining your day.
The fins might look like a stout piece but trust me, it will break off.
Old Feb 7, 2010 | 10:07 AM
Dr. G's Avatar
'09 E63 AMG sedan (sold); E36 M3, E90 M3
Got to ask a basic question: why not just use the designed rear jack points? you cant miss them...
Old Feb 7, 2010 | 01:53 PM
hgerhardt's Avatar
E63
I assume you mean the ones on the body: because you can only lift one corner at a time. And if you want to set the car on jackstands, where do you place them if you've got the jack in the way? You've got to be able to lift each end of the car from a center point.
Old Feb 7, 2010 | 03:23 PM
Dr. G's Avatar
well, if the reason you can only lift one corner at a time is that you only have one jack, go buy another jack!
Old Feb 7, 2010 | 10:10 PM
hgerhardt's Avatar
E63
You actually think it's OK to crawl under a car with two hydraulic jacks holding it up??? No thanks. I want the car supported by jackstands and that's impossible if the car's jackpads are being used by the hydraulic jacks.
Old Feb 8, 2010 | 09:57 AM
Dr. G's Avatar
ok, i get it now,and agree with you 100%.
Old Feb 8, 2010 | 04:10 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
You should be able to put the block under the differential and lift the car up without any problems. I've seen Juicee and a couple of other guys do it at the track a few times in the past. Just make sure you avoid the fins as Yullie36 mentioned, they WILL break off.
