Coilovers on an E55
http://thmotorsports.com/kw_suspensi...025005-06-2006
https://mbworld.org/forums/w211-amg/...-w211-55s.html
I would love to have coilovers on my car if I didn't have a Pano piggy roof...that flexy piece of glass will always hold my car back...
https://mbworld.org/forums/w211-amg/...uspension.html
Years ago I thought it would make the car handle better, now that I have done some work on the AirMatic I am not so sure. We need a skid pad and a e350 w air matic and a E350 w steel suspension a G meeter. Can a 4100 lb 4 door car handle? My answer no but that comes from a 1800 lb. mid-engine point of view. I like the comfort for long trips my fatigue level is greatly reduced.
The only real advantage might be reliability, the rebuilt struts now cost the same as a KW coilover so cost is not much of a factor.
They have had it way worse in regards to air suspension problems. Their most common and cost effective solution was to throw CO's on and ditch the DRC system.
I for one appreciate the smoothness of the air suspension, especially now that I have lowered it slightly with an ELM. I have had my share of cars with tight suspensions and am really enjoying the change. Charging the twisties occurs a lot less in my daily commute than I prefer...lol.
As for reliability, I too would love to have a CO suspension vs. airmatic. Maybe when my warranty is up in 5 years, there will be a well tested solution available. SW certainly has the resources to explore this, and I wish him god speed, as we will all benefit from his research.
I just talked to my Shop Foreman at American Service Center in Arlington, VA. He said that the airmatic suspension can be replaced with the stock or coilover setup. The bolt holes are the same for either setup. You will need to use the Star to disable the airmatic functions though. So you now have a green light to start modifications, please post pictures.
I want to know if this works!!!!!!!
