0780 Replace fuel filter
When you say filter, the image of the those little filters on the old cars come to mind for many. Nope, not for the ole Benz-o-matic.
You will need the ENTIRE fuel sending unit to do filters.
Believe the part runs either 600$ or it's 600$ PER as there are 2 units. Gas tank is a saddle tank right under your rear seat with tanks on each side of the hump.
Install should be a couple hours labor and there is a chance car will smell like gas for a week or more.
For something like this, you just gotta go to the stealer IMO.
KEEP IN MIND. There has been a long standing service notice on the fuel filters and with the repair, many times they just throw in new filters/sending units with the fix. Check with stealer to see if yours qualifies and keep your fingers crossed.....and maybe keep a hundy on hand for palm greasing.
Info on service.
So I just put Techron fuel cleaning every oil change (approx $7)
Or you can just use it once every 1k miles to keep it clean.
1. I checked on the service bulletin for my VIN and the deal said it didn't apply. Mine is a 2004, so maybe it was earlier mfg dates? Not sure?
2. I found out there's a fuel sending unit that has the filter and another fuel pump on the other side. The dealer said the earlier is what's replaced for the filter. Gave me a price for parts of $269, plus a $16 wire harness (not sure what this is for, but it's only $16) and a $20 bracket. The other fuel pump without the filter is $315. Wondering if they changed the version/design, which is why it calls for a bracket? Maybe someone can clarify?
3. My local shop that only does Mercedes quoted me $460, so I'm assuming they don't replace the second pump without the filter. Can anyone confirm if this should be replaced? I know on a lot of cars, the fuel pumps last well over 100k.
Hope this helps someone else. I plan to do it myselft when I confirm the pumps and what needs to be replaced. I'm pretty new to the site, so I will try to add some how to pics to donate to the cause.
thank you!
