82mm- Shaft ported to 85mm
PLATINUM SPONSOR
I originally shaft ported my 74, then my 80 and now my 82mm.. Been holding off, as with stock manifolds still on thre car, extra TB flow is now doing much.. Hope to have headers pretty soon, so I did a little pre-grinding..
I am sure we would all like to see before and after dyno numbers and bench flow numbers , as well as have a dyno in our garage.. I test what I can and when I can but this is just one of those mods I like and do regardless.
I did a very conservative grind job on this TB and only removed about 40% of the shaft material .. I still need to clean up the top inlet side and grind off the screw threads on the bottom but you can get the idea..
Mathamatically speaking, this will increase the flow area to an 85mm TB.. Just flattening off the top of a round shaft will increase flow and cut down on turbulence..
Stock 82mm inlet side, before grinding.
Stock 82mm TB motor side.
Ported shaft motor side and I left screw threads sticking through to help show material removal. I also red locktite these and then smooth off after they set for a few minutes.
Another pic; showing flow angle on ground shaft. Top screw head side is ported left and screw heads are left intact.
Here is another shot before grinding screw tips off..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Cable driven Tb`s are very easy to take apart and bore out but our fly by wire TB`s are very tricky on these MB`s..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Another option, is that one of the tuners figure out how to adjust our TPS calibration, so we can keep a smooth idle and no codes.. Maybe just raising the idle a hair would solve the problem.. Just ideas and thoughts..
Sounds like you are game to try, so please let us know how it goes and I will send mine in too..
__________________
www.ultimatepd.com
www.ultimatepd.com
