**PLEASE HELP** 180 Crank pulley touching water pump pulley...
Old Feb 19, 2010 | 07:29 PM
beauphus's Avatar
CLS55 & CL CK60
Hi all. I finally got my car put back together and notice my crank pulley is touching my water pump pulley. Its scraping the outer edge of the water pump pulley. Anybody ever have this issue? Here is a photo...
Is it possible my crank pulley is flexing into the water pump pulley under torque? Is there something I am missing? I am running a renn-tech 180 pulley and if other are talking 185 or even 190mm pulleys I dont understand how they arent encountering this issue...
Please help. This cant be good
Old Feb 19, 2010 | 07:48 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
did you replace the waterpump pulley when you installed the 180mm? if you have not - there is your problem.
Old Feb 19, 2010 | 07:57 PM
lowprofile's Avatar
E55
^ That is the renntech waterpump pulley. Just stating the obvious, are the water pump pulley and crank pulley tight?
Old Feb 20, 2010 | 01:08 PM
jangy's Avatar
2015 S212
You need to put on a smaller water pump pulley to go along with the 180mm pulley, especially if it has big ridges.
EVOsport sells them. They are called underdrive pulleys.
Old Feb 20, 2010 | 02:07 PM
beauphus's Avatar
CLS55 & CL CK60
So u mean to tell me the renntech pulley and the renntech waterpump pulley are not built to work with each other? That doesn't make sense...has anyone else faced this problem with the renntech pulley package?
Old Feb 20, 2010 | 07:44 PM
lowprofile's Avatar
E55
Yes, those are made to be used together. Instead of making the wp pulley smaller, they tapered the leading face. So, while idling they do not touch? I would like to hear their response.
Old Feb 26, 2010 | 01:08 PM
lowprofile's Avatar
E55
Any update?
Old Feb 26, 2010 | 01:40 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
+1
Old Feb 26, 2010 | 02:16 PM
pun1sh3rz's Avatar
Current: 2004 E55 Sold:350zTT
Originally Posted by emoving
+1
+2
Old Feb 26, 2010 | 02:21 PM
jangy's Avatar
2015 S212
My mistake, I did not understand that you got a RennTech 180mm + their water pulley solution.
Metal to metal can't be good......
I dunno how the water pulley is but make sure all four bolts are tight. The EVO one is very easy to deal with. You may wanna consider just getting it and not dealing with RennTech. You'd be foolish to think that they will reply to this thread or release any information on revisions. Just keep your Renntech water pulley and see if they haven't changed the design without saying a word in just a few........
Old Feb 26, 2010 | 04:01 PM
beauphus's Avatar
CLS55 & CL CK60
the mistake was not on their end. it was my blunder. the issue has beeen revised and resolved...
Old Feb 26, 2010 | 04:19 PM
jangy's Avatar
2015 S212
They sell one without the other? Anyhow, sounds like you are good to go!!
