e55 problem car loses power randomly
Use the search function and you should find a ton of good discussion on it. Lots of people replace their stock IC pumps with a Johnson pump that seems to work better. I had a Renntech pump installed on my SL55 along with a additional heat exchanger to help keep the SC cool. I think there is even a DIY on IC pump install.
Good Luck
IC pump failure you wont really notice that much unless you are racing with someone then you see the different. Without the SC, the car should still running fast 349hp 391 torque.
If you had then you would relize the symptoms are exactly what he's describing. I had the OEM Bosch pump go bad and that's exactly the feeling of the car falling flat on it's face.
