Evosport | New Lightweight 2-Piece Front & Rear Rotors for W211 E63 AMG
Old 02-23-2010, 12:46 AM
PREMIER SPONSOR
Simon @ evosport's Avatar
UP TO 40-LBS WEIGHT SAVINGS!
Designed as a direct brake rotor replacement for the OE 1-piece or 2-piece brake rotors (front and rear). No modifications are necessary. The Evosport rotors will bolt directly to the car and work with OE AMG brake calipers. Not only will the upgraded multi-piece "floating" rotor design help mitigate brake fade, but are lighter than stock and reduce unsprung weight by up to 40-lbs. on all four corners! Note: 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors. This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Drilled and slotted to match the OE rotors, hats are lightweight aluminum and hard anodized. And unlike the stock rotors that only vent correct on one side (or have universal venting), the Evosport rotors have a Right and Left application for proper venting of the disc and chaneling of airflow.
Benefits:
  • Direct bolt-on design requires no modification
  • Works with OE AMG calipers
  • Lightweight design (up to 40-lbs unsprung weight savings over stock! 26-lbs weight savings on vehicles equipped with 2-piece OE front rotors.)
  • Aluminum hat, hard anodized (Black)
  • Better value and cost of ownership over OE! The OE 2-piece 360mm rotor sells for $990 EACH!
  • Unique Left/Right application for proper venting/airflow (unlike OE)
  • Replaceable discs and hardware
  • Better heat dissipation and less brake fade
  • Improved acceleration, braking and cornering with less unsprung weight!
Includes Front and Rear rotors with black anodized hats (Front or Rear pairs can also be purchased separately). For more information or to order, CLICK HERE.
Please feel free to call or email us with any questions.
Anthracite anodized hats shown below. Actual rotors have black anodize:
Evosport 2-Piece Rotor Installed on SL63 AMG (Note: Right-Side Rotor Shown):
Old 02-23-2010, 05:01 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Wow, these look very good
Simon, did the E63 brakes ever come in two versions? 1 piece vs 2 piece? I have the performance package E63, but to my knowledge there were no changes in brakes compared to the regular E63... What are the diameter of these and the 1 piece OE ones?
Old 02-23-2010, 05:19 PM
PREMIER SPONSOR
W211 and W212 E63 came with 2-piece front 360mm rotors. The W212 has optional composite ceramic option (not for USA).
Old 02-23-2010, 07:40 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
Do C's and CLK's have different mounting than E's and CLS's..??
Old 02-23-2010, 09:36 PM
PREMIER SPONSOR
What do you mean by mounting?
Old 02-24-2010, 09:54 AM
gonzales25's Avatar
Slow
Can I just re-use my stock hats and buy the rotors?
Old 02-24-2010, 12:28 PM
Oh...Nevermind...I just saw it in that forum...
Old 02-24-2010, 02:24 PM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Unfortunately, Mercedes doesn't reuse the hats, I don't know if Evosport will mount a new rotor on a Mercedes hat. I think that the bolt pattern is totally different. I believe that the hats maybe larger in diameter then Mercedes. But I do know that Evosport will remount a new rotor on their hats for you. I'm looking at getting a complete set for my E63 very soon, even though I don't need brakes or rotors yet. Knowing that the rotor surface can be replaced is a big deal for me. Mercedes just throws the whole dam thing away. Since Brembo makes the calipers, I think that they make the rotors as well. It might take some looking into, to see if Brembo will mount a new rotor disc for you, if you decide to keep the hats. I know that would be allot cheaper then buying new rotors. I like the Evopsort ones, due to there lightness as compared to OEM.
Old 02-24-2010, 04:33 PM
PREMIER SPONSOR
You cannot re-use your OE hats. The entire OE rotor is a toss away once it's done, and you have to buy them in pairs from the dealer, so it gets $$.
With our setup, you can re-use our hats when you need to replace the disc.
Old 02-24-2010, 04:35 PM
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
that 35 lb savings i take it is based on all 4 rotor ? Or per each ?????
Old 02-24-2010, 04:38 PM
It's all 4 together...26 lbs actually...
Old 02-24-2010, 05:00 PM
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
So rule of thumb is for every 10 pounds u drop of rotating mass is like dropping 100 pounds and or like gaining a tenth ?
This is my next mod along with the Quaife , Screw the 930 lol
Old 02-24-2010, 05:48 PM
I thought it was like every pound of unsprung dropped equals like 5 of sprung..? Not sure...hell yeah a Quaife..!!
Old 02-24-2010, 11:04 PM
jangy's Avatar
2015 S212
The AMG hats are heavy as well. I will be honest the AMG 63 2 piece fronts are very robust and do better than the E55k fronts at heat dissipation. BUT, they save NOTHING (actually 5lbs) in terms of inertia and that is where the EVOs actually generate less heat and thus need less cooling (sort of)
Old 02-25-2010, 01:14 PM
PREMIER SPONSOR
Conservatively, 4:1. But it's more to do with amount of energy required to spin rotating mass.
Old 02-26-2010, 07:43 PM
YEah, just freeing up power thats already there...
Old 03-02-2010, 10:49 PM
gp500e's Avatar
2006 E55
What's different between these E63 and the E55 versions?
Old 04-17-2010, 12:59 AM
dilemma415's Avatar
E55
So if I decide to pick up a set of rotors from you guys, Let me get this straight, it comes with front and rear rotors and the Hats. Or Hats are sold separately?
Old 04-17-2010, 11:38 AM
Tom_Boy's Avatar
2003 CL55
Survey says???????? Price please?
Old 04-18-2010, 03:12 PM
PREMIER SPONSOR
It comes COMPLETE. You can buy just the discs later when you need to replace them instead of having to buy the entire rotor again. As a side, when we say "rotor", we mean entire assembly made of hat, disc and hardware.
$1,999 for all four corners. Here's the link again to more info and pricing:
http://www.evosport.com/product/prod...VO.BRK.M12.R01
Old 04-18-2010, 03:21 PM
Tom_Boy's Avatar
2003 CL55
Great Value... My fronts look 10 times worse than the rears (I picked it up with 16K miles) maybe the fellow who had it was as aggressive on the brakes as he was the throttle... Simon, any split pricing for fronts only/rears only? You sell/recommend any specifc pads designed specially for the rotors? Also, do they have any special treatment? Cryo, etc?
Thank you!
Tom
Old 04-18-2010, 04:02 PM
PREMIER SPONSOR
Thank you!
Tom
Split pricing is also in the link above, but $1,299 for front pair and $990 for rear pair. Rotors are zinc plated.
For pads we recommend OE, Pagid or Akebono for street application.
Old 04-19-2010, 06:19 PM
dsC32's Avatar
'07 E63; 05 C55 gone; '02 C32 gone;1996 SL320;1978 280CE Gone
Simon, I've used Pagids on my C55 (1427 is the size designation for the fronts), but do not know the size number for the front pads tol fit my 2007 E63 (front). Do you have that info? Glad to hear you have directional vented rotors. Will probably replace mine with your product when the time comes. How much do you charge for the rotors without the hats?
Old 04-19-2010, 09:17 PM
sack5000's Avatar
2015 AMG C63 S
Is that in any order so Akebono works as well as OEM? Thanks,
Old 04-26-2010, 08:42 PM
sack5000's Avatar
2015 AMG C63 S
top
Quick Reply: Evosport | New Lightweight 2-Piece Front & Rear Rotors for W211 E63 AMG
