Would W211 OEM e55 wheels fit on a E55 W210?
CLS55 AMG 030
Would W211 OEM E55 wheels fit on a 2002 W210 E55? If so does anyone have pics of it? Thanks ( sorry for my lack of knowledge of the W210 platform)
2003 E55 & 2014 GL550
Quick couple searches and I found that bolt pattern is the same 5 x 112 as our W211s. Only question would be offset at this point.
Maybe a question to shoot over to the W210 guys.
Gotta be someone who has thrown the W211 rims on the older 55's.
CLS55 AMG 030
Ya I knew the bolt pattern was the same, I posted on the W210 forum and no responses so i decided to post here. I searched and couldn't find it any where. Thanks
2004 W211 E55K, GL550
nope fits perfect my cousin had a w210 E55 and he wanted to try out my stock wheels and they bolted right up no problem what so ever i also took my aftermarket wheels on my W210 and put them on my W211. Bolt pattern and off set was dead on. Hope that helps.
W211 wheel will fit W210/E55 if wheel offset of front is 31-35mm & rear is 35-41mm, just reuse your own lugs.
fyi, I notice on my W210 E55 that the center bore on the front and rear are different. I bought some spacers (66.5mm) and they fit the rear but not the front but according to everyone wheel's guide it (66.5mm) and it should fit
Administrator
I've had several questions on that myself for my FS wheels. The bolt diameter as listed in this thread as well as the offset seem to be correct. I had someone test fit them on his regular W210, using his bolts. They fit but it is not recommended to use the smaller diameter bolts. His car was not lowered so there wasn't a fitment issue with the tires mounted on my wheels. We looked with mirrors to check for clearance issues: fronts when turning, etc. Keep in mind that all of this was done static, no load. Also keep in mind that his car was not lowered.
Here is info on the necessary bolts I've been told
RAD lug-bolts
Item # 20-4067-B
RAD 12mm x 1.5, 26mm Shank, R14 Ball Seat
http://www.otisincla.com/
YMMV
RAD lug-bolts
Item # 20-4067-B
YMMV
