New ASP S/C idler tensioner pulley and kit.
PLATINUM SPONSOR
The last of the fugly pulley`s on my car is gone now!! That S/C tensioner pulley was one ugly part and has the same low rpm bearings in it , as the S/C idler we all have fail..
I also had a new light weight water pump pulley made with a step in it to bring water pump speed back to stock rpm.. This pulley is 50% lighter than stock and maybe 100% lighter than some of the aftermarket models that come in some of the kits..
The lighter all your pulleys`s,, the less horspower wasted to try and turn thr weight. This also helps the engine rev quicker or get up to speed quicker.. Will I feel it, probabally not but every little bit helps..
ASP said they were going to run some of all of them and just make a light weight , high speed bearing dress up kit..
I just wanted nice custom stuff for my car , that was light and had good bearings.. Glad they running some extra parts and my extra work on it is helping others out..
ASP S/C idler next to ugly steel s/c idler.
Instal pic of S/C idler.. BTW, two minute job to change..
New light weight ASP water pump dress up pulley.. Still need a cap to cover ugly threads..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
Nope, I think old people watched that show and maybe a few wise *****.. No time for TV..
__________________
www.ultimatepd.com
www.ultimatepd.com
any price info and contact info. how much and who do we call. looks nice , I sure would like light weight pretty pulleys. still deciding on which SC pulley to get. pretty happy with power now but simple pulley swap seems like a no brainer. is it true if you go 168 you dont need to change the lower pulley or belt. even simple. except the monster bolt to replace.
Current: 2004 E55 Sold:350zTT
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
It is true -- and a tune is not mandatory -- but best results getting a new tune after any mod --
PLATINUM SPONSOR
Bottom line,, I have my parts and on to the next fun project for me! Be happy to help with any questions though..
__________________
www.ultimatepd.com
www.ultimatepd.com
Chevy Camaro
