4 custom pulley`s on , tested and one to go.
PLATINUM SPONSOR
I have replaced and tested 4 of the 5 pulley`s custom I plan to change out..Just tested the accessory tonight for fit and function.. All perfect fit and function..Even though I had no noticable noise at this point, all the pulley`s and belt run a lot smoother/quiter now..
First, I changed Idler, then the water pump pulley, S/C tensioner pulley and finally the accessory idler pulley..
Going to work on eliminating the S/C clutch and make a smaller S/C pulley.. Custom pulley fees add up but well worth it for me at the end of the day..I really like custom high quality billet pulley`s on my ride and with high speed bearings, can sleep well now..
Also going to have made a custom S/C tesnioner made soon. Few details to work out.. I want some belt slip but still getting more than I can live with..
Stock S/C Idler and plastic Accessory pulley set..
![](http://i991.photobucket.com/albums/af31/Vitabc/stockidleraccesory.jpg)
ASP custom S/C idler and Accessory replacement set next to stock set..
![](http://i991.photobucket.com/albums/af31/Vitabc/stockandasppulley-1.jpg)
Left: Accessory idler. Right: S/C idler pulley
![](http://i991.photobucket.com/albums/af31/Vitabc/asppulleyset.jpg)
ASP Billet S/C tensioner next to stock metal pulley
![](http://i991.photobucket.com/albums/af31/Vitabc/scidler.jpg)
Custom light weight billet water pump pulley @ 50% less weight.
![](http://i991.photobucket.com/albums/af31/Vitabc/WPpulley.jpg)
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Right when I just put the crack pipe down and thought the ole addiction was over- u had to show me all this stuff... Looks good!! Might have to see your idea with sc clutch is going to be
CLS55 & CL CK60
curious about your clutch idea as well...what would the benefit be of eliminating clutch?
PLATINUM SPONSOR
Forrest Gump 9 That's some really nice and high quality pieces. Are they available to the public or one off made for you?
Yesterday 11:17 PM
Yesterday 11:17 PM
Cal1 was kind enough to ship me his S/C pulley clutch assembly to help the cause.. I have to thank him for the donation to the cause. Next, I will have to go to ASP and beg them to do another custom part for me..
