Need to be pointed in the right direction
Maybe im just using wrong phrases.Can someone point me to the proper threads?
Thanx!
btw, govoriti srpski?
The Car i'am looking at is a 2003 with 60k miles,one owner local car,traded for a E63 at the dealer where it was purchased.Extensive maintenance record and fully loaded with Keyless GO and power sun shade,Suede Headliner,Power Close Trunk etc.
I da,naravno da pricam Srpski....
Cako si brate!2003 is not too bad. The airmatic will eventually go out, maybe the intercooler pump, and supercharger clutch assembly... But other than that the car is pretty solid! An extended warranty will work out in your favor on multiple occasions!
Thank You.
It sounds crazy to believe that the 03's were that bad where i should stay away from them in general.
I appreciate your input and all the help.
Hvala!
Ziveo
And the 2003's DO have some "known issues"
like what?20kCommon man if i could buy a 63 i would.Or i would go for a 2005 E55 Certified.
So your argument is if i buy an 03 E55 i need to make sure to have 10k on the side for repairs?
Anyone else with a comment that will make some sense?
Even if the car is an 03,im thinking a lot of the problems have probably been delt with already,no?warranty won't work in my case because i'm taking the car back to europe.
