Eurocharged, my personal experience with them
) will probably come out and tune the cars if you can organize enough people
Is the tuner world that far gone from our everyday experiences from normal vendors they get a pat on the back for a job well done such as returning money for services not even rendered? I guess so, which is pretty sad.
How often do we see glowing reviews like (paraphrasing) "hey guys, I just wanted to share my great customer experience recently. I called Tuner Co. and John Doe answered. We talked for 20 minutes, I explained what car I had and what I was looking for. He suggested A, B, and C parts to help me reach my goals; I agreed, so he took my CC information and said the parts would ship by the end of the week. Thanks Tuner Co.!" Is that all it takes for an "atta boy" from the clientele of the automotive aftermarket? A shame our standards are so universally low, if so.
Some tuners comprehensively warranty their own work too. This is more important to some customers than others, and it tends to coincide with the higher-dollar shops. Dinan and Renntech are good examples (and have been in biz for 20-30 years; which makes the warranty potentially more meaningful), among others. What you won't find, is someone covering a claim on someone else's product/service. Insurance policies excluded, of course.
Doesn't matter to me, I'm NA so blowing my motor would be really tough and the only real tuning reason for me was to pull off all the limiters.
1) Would the persons tune be considered custom, testing, trying to get the most out of - Responsibility would fall on OWNER (This example is a "TEST" environment, **** happens, its because tolerances and history have not been followed, you are asking the tuner to take your car to its 'potential' ...which falls on lots of hardware to hold up their bargain) | This is the pay to play situation ...
2) Proven Tune, you essentially by a copy of a pre-mapped tune for your particular car, that **** blows up after you have it on (melted piston etc) ...the responsibility falls on the TUNER | That tune should of been locked down with acceptable tolerances. Something melts, that 'prefab' tune sucks monkey nuts and they need to get it fixed.
Anytime you try to get take the hardware over manufactured specs, you risk something happening, obviously we all know that. But if a product has been tested and stamped off by a tuner as a VALID product, pre-checked, tested and verified for a particular vehicle, they should be responsible if a set of events take place <pre-defined> that should not from the tune.
If a tuner would spell these out (I.E, you buy my <x> tune, I guarrentee your engines not going to melt from it, provided you have all required sensors in place (O2, MAF if aval) ...essentially everything that f's with A/F.
If you go in wanting something custom, the owner needs to go in it knowing ..."my **** could melt on this dyno, but i have some confidence in teh tuner I have chosen to make a good professional decision in his choices of remapping, because I have confidence in their understanding of the ECU"
Just my 2 cents ... plus a nickel
As I understand it, many dealerships nationwide are also Renntech and/or Kleemann authorized dealers and installers. They can tune brand new, or used vehicles. The warranty policies of Renntech, Kleemann, Dinan, et. al. can usually be found on their respective websites. Sometimes they have specific language about adding coverage where the manufacturer voids their own coverage for the tuner's hardware and/or software.
These threads are less about the motor actually blowing and more about the customer service, or lack there-of, that was received after it happened. Find me one customer that EC has blown their engine and remedied the situation satisfactorily. So far they are 0/3 that I am aware of.
Like I said, is the moral of the story that EC is great right up until you really really need them?
And no man, I do not totally disagree with you, just stating a different side...
I understand racing, good service and a good tune.. I have no fear at all for Jerry/EC to keep tuning my car.. He shows me exatcly wht he does on my maps and I know it is safe and to my specs.. When my car gets up to 550 plus RWHP like some of these cars,,, you can bet that larger injectors will go in, fuel pressure checked live in 4th gear (up to 140mph) and a re-tune to tie it in.. I am damn sure that I will not put all that HP on stock fuel sytem and then go crying foul about a tune, if i run out of fuel on old stock injectors.. Those people hurt the whole industy and the people that work hard to create race parts for us.. Really, you think you can add cams, pulley, LT, TB and other bolts, make 560hp SAE corrected and expect stock fuel system to handle 150RWhp over stock? LOL .. Oh yeah, also have a ton of miles and who knows what kind of gas junk pumped into the tank over the years..
Jerry/EC even made custom Long Tube headers for my CL class frame (been trying to find some for a year) and then offered to come over and help with the install.. Said he just wanted to make sure everything was they way I wanted and fit was good.. Oh yeah, and Gregg miced everything and sent a part back, as it did not meet his spec.. Then second day aired them to me to make up for the delay.. Damn! That is good customer service!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Also, knowing that stuff can happen, doesn't that make the response from EC that much more important? Maybe EC wants to do the right thing, but can't afford it, maybe they don't want to do the right thing, who knows. Either way the customer is stuck.
Hopefully does, anyway.Oh, FWIW, I'm the same way - usually wait until my cars are out, or at least almost out, of factory warranty before embarking on anything extensive mod-wise. Just seems more prudent, but everyone's different on that topic.
I think the warranty thing is like a safety net in my mind. Who knows what all MBUSA will decide to void if you change one thing in the engine. The tranny and rear end too.?? That's why I usually wait. I don't want to give em a chance to sneak out of an actual defect with the excuse I voided it
I personally have also had great dealings with the guys at EC that leads me to believe that their customer service and products/promises are top notch. Granted, as you have so eloquently stated, I have not had an engine blow, and therefore, have not had to deal with them from that perspective. That being said, the dealings that I have had with them have been top notch. And if that places me in a 99% majority, well, I think you would be hard pressed to find a similar satisfaction rate across a WIDE variety of industries (not insinuating that they, indeed, have a 99% satisfaction rate but meerly using the numbers you have provided).
If true, that the tune is responsible for the detonation of the engine, I agree with the assertion that EC should be responsible. Does that statement change how I was treated in my dealings with them? Simply, no. One has no bearing on the other. I had a positive experience, the other person did not. Our ability to relay positive experiences with a vendor are just as vital to the forum as the unfortunate members who have negative experiences. Both provide valuable information for other members in order to make an informed decision.
Sticking with what I know (and addressing my original statement): the five year survival rate for a kidney transplant patient is:
White: 73.9%
Black 60.8%
Hispanic 75.%
Asian 79.6%
Much lower than your 1% acceptable threshold (as with most things in the real world). The vast majority of your argument, I found myself agreeing with (still do); maybe it's just me, but the area I work in, the acceptable statistical confidence intervals are 5%, 1% risk in my book is completely and totally acceptable.
First, I realize that failure rate is typically measured in units of time (hence the word "rate") however, for purposes of this argument it is very difficult to analyze it in that manner. I never said anything about satisfaction level. I was only talking number of blown engines that have (on this website) been attributed to EC vs the total number of tunes they have done (estimated by Tony). That has nothing to do with satisfaction level. It is a measurement of known blown engines vs known tunes, hence 3/300 or 1%.
White: 73.9%
Black 60.8%
Hispanic 75.%
Asian 79.6%
So on to aleks. So, mercedes says it was a stock tune on the car when it had its error. Yup, that must be a tune error as well. It was an 03 with a ringland failure that caused the issue. (documented by a few on this forum to have the same problem on their stock and modded 03's) Not to mention the owner did things like put an extra heat exchanger held on with coat hangers. You read that right, coat hangers.
This newest problem will be well documented for all to see, and you know I am looking forward to it. There is more to the story and that will be shared in due time. We have always stood behind the products and will continue to do so.
Bottom line is no matter what you do to your car with anyone, things can happen, with ANY modified car.
ps. Ill let you know. ORP opens at the end of the month, my new nittos drag radials will be in on tuesday! see ya buddy!
Whether it was intentional, or not, the perception that "If you have an EC tune, your engine is a time bomb" got out. What I find interesting was so many people came to the same conclusion. Thats not an accident. All of this was done before a diagnostic of the actual problem was done. Is it right to put that perception out there without having the post mortem? Once again, opinions are going to vary.
I really don't have a dog in this race. I do have an ECU tune by them (no pulleys or anything else) and I bought my CF air intakes from them (love 'em). I enjoyed both transactions and interactions and am a very happy customer. If they have something that I need at a competitive price - I will continue to do business with them.
I see your point as far as enhancement surgery being analogous to a tune, however, you would surprised how easy it is to have an infection caused by a surgery kill a patient and not show up as a surgical death because the patient died of an "infection". I'm not saying that is the case with what you quoted, but 500,000 patients, by definition, cannot be adequately controlled or followed. I was using transplant data because comparatively speaking, it's a small patient population that easily followed and all data is monitored by an independent third party UNOS. Does it make it 100% accurate. No. But it's fairly decent data.
Even though we differ in certain areas, I really do like the way you present your point of view
Normally I’m the only MB… well let’s say, non American car out there. There were some ricers from Fort Wayne once. We kind of huddled together like outcasts. That was until we ran down the track and earned some respect. I don’t think the hayseeds expected to see a Benz run sub 12 or a Lancer turning 12 flat. Muncie is a long haul though for a Wednesday night “Test and Tune” especially for the Lafayette boys. I guess ORP will do.
