Crank Shaft Position Sensor?
10 E63
Ive done some research but wanted to see if anyone else has experienced this?
A few weeks ago, my car engine shut off as I was approaching a stop. I simply put the car back in Park and restarted. No CEL no nothing for a few days. Then one day when I tried to start the car, it simply wouldn't start. The started was turning over and over but the engine never fired. After about 10 tries it finally started. The CEL also came on but disappeared after a few successful starts.
Days later, the car died again as it was coming to a stop. The car also has an issue starting for awhile but eventually worked.
Is this symptoms of a fault crank shaft position sensor? Is this DYI?
1 Post
2005 e55 amg
I had this happen to me once (in big traffic) about 12 months ago. Car restarted after I turned key back to off on and on again. Hasnt resurfaced though, but at the time was diagnosed by the internets as a CPS
