Opinions on my intake.
Old 03-24-2010, 12:29 AM
sneakyneon's Avatar
Bicycle
So I understand that my method of moding my car may not be conventional but intrested to see what others have to say about my latest attempt to find some budget minded HP. This prodject has not been dynoed but what got it started was the last time I went to the dyno I made 1 pull at 456.4hp/522tq then pulled the airbox off with no cool down a put down 500.59hp/539.7tq with an open TB. Every thing is 3.5 and manderal bends.
Old 03-24-2010, 12:46 AM
KLR CLS's Avatar
CLS63 PP
I would be interested in hearing your impressions and maybe a back to back dyno with the stock airbox. I was thinking something similar. I don't care much about looks, and 2K for an airbox blows my mind ( renntech/Carbonio) pretty as they may be. Kudos if it works well.
Old 03-24-2010, 12:50 AM
KLR CLS's Avatar
CLS63 PP
Hey what TB are you running on that thing?
blackbenzz's Avatar
haters crazy
You gained 44whp by just pulling the intake off???
Old 03-24-2010, 12:54 AM
sneakyneon's Avatar
Bicycle
I know! I would not even had mentioned if there haden't been 10 witness to it, I think some of the gain might have been in the computer adaption? but its just guess. I made 4 pulls total, one with a stock modified to fit an 82mm TB then no air box then 2 with meth. My car is still on a stock tune....
Old 03-24-2010, 01:04 AM
sneakyneon's Avatar
Bicycle
Its an 82mm
Mods are
178mm pulley
82mm tb
shortie hearders
no cats with 3 inch pipe into magna flow mufflers
Upper and lower spacers for surge tank and blower
Water/meth injection
trunk water resivior
Very large Heat exchanger
mild port and gasket matching to the blower ,surge tanks IC. (very mild)
No tune...
Old 03-24-2010, 01:09 AM
cahiil55k's Avatar
211-55
I think that setup works great on a dyno with fans blowing and an open hood, but once the hood shuts and your racing, the engine bay will retain more heat and you might lose a little power. I know when I'm at the drags, the metal beneath your cone filter gets hot enough to evaporate my ice water for a few minutes.
Edit: Just saw that you have a meth setup which will help with the IATs.
ahmad0658's Avatar
Brabus K8 E55 05
What kind of filter is that ?
How about if it was possible to make Y connection and plug another one on the driver's side ?? how well the improvement will be?
Is there any drawback of making the filter exposed like that? engine heat maybe? dirts? sand like in our countries over here in the gulf ??!!
Old 03-24-2010, 01:26 AM
sneakyneon's Avatar
Bicycle
the biggest draw back is under hood heat, My thinking is the flow will out weight the heat issue, its not like the stock set up is much better, yes its sealed but the boxs get heat soaked in no time, The filter is a amsoil. 3.5x 9 long I belive. what mods do you have on your car?
Old 03-24-2010, 01:33 AM
ahmad0658's Avatar
Brabus K8 E55 05
I have Brabus K8 package (Pulley + ECU), KLEEMANN headers, Brabus exhaust with 3 tips each side, Brabus anti lock differential, Fluid Motor Union Tune, K&N filters.
My 82mm is shipped today in your time, so, it will be here within 2 - 3 days along with the phenolic spacers (up and down).
I also have PLM HE and Johnson pump waiting the above parts to arrive so that I can install all of them together .
Last dyno number with my current mods was something like 500 whp.
Old 03-24-2010, 02:33 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
woah woah woah... glad to see you're still up to no good
Old 03-24-2010, 04:17 AM
jturkel's Avatar
02 C32 AMG
sneakyneon: don't they make a heat shield that you could wrap around the intake filter to help prevent heat from creeping in?
Old 03-24-2010, 08:34 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Wow glad to see a different set up. What does your butt dyno say, do you feel a increase in power. In terms of sound is the s/c louder
Old 03-24-2010, 08:51 AM
930chas's Avatar
cornfed gtr and m3
Wow!
Props for trying something different! I am definitely curious about this intake as well, sound and butt-dyno-wise!
Old 03-24-2010, 08:56 AM
pun1sh3rz's Avatar
Current: 2004 E55 Sold:350zTT
+1, subscribed
Old 03-24-2010, 09:18 AM
blackbenzz's Avatar
haters crazy
I'd like to see track number comparisons if possible. I had a somewhat similar setup on my car before but with a longer 3.5" pipe and cone filter closer to front of car. I think it lost mph on the back half but I'm not sure. I have a new intake as well but no way to determine the intakes effect alone since I turned the boost up at the same time and it isn't a simple swap back to the old intake.
Old 03-24-2010, 10:09 AM
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
Nick - i tried to run an HKS filter right on top of the throttle body and it was horrendous. under the hood temps get so high that what you see on a dyno with the hood open is not nearly indicative of what you'll get driving.
I for one don't think that your filter is in a good spot since I tried that and car was very very sluggish (sounded great tho). I keep forgetting that you run water meth which brings your IATs way down so that intake should work well for you in comination with W/M.
Old 03-24-2010, 10:16 AM
blackbenzz's Avatar
haters crazy
Just reread and noticed this. Be careful! You have a wideband in your car to watch AFR's?
Old 03-24-2010, 11:47 AM
sneakyneon's Avatar
Bicycle
So drove the car this morning, But dyno says its at least as good as stock and would have to say that its quite possible better. I"ll have some track info in a few weeks to fallow.
Now for the sound... Wow. insane whine, much like the SC cobra's. I also removed the sound deadner and that might be part of it, It was pretty tattered and beat up and think.
Old 03-24-2010, 11:48 AM
sneakyneon's Avatar
Bicycle
I do, its a zeitronix, Afrs this am were around 12.4 with the meth off. I tend to gain a point on
Old 03-24-2010, 01:21 PM
sneakyneon's Avatar
Bicycle
I too tried that filter on the TB and was less than impressed, I tried it at the track once and lost 2 mph from the stock one.
After my 20 min drive to work the filter was hot to the touch but the small metal connector was cool and the TB felt cool. I'll log some IAT this afternoon or tommarow.
Old 03-24-2010, 01:40 PM
jcjmw's Avatar
2005 E55 Wagon
Originally Posted by 930chas
Wow!
+1, Yes most definitely agree!!
Old 03-24-2010, 08:36 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
very interested
Old 03-24-2010, 09:46 PM
beauphus's Avatar
CLS55 & CL CK60
what kind of water/meth system r u running? do u like it?
Old 03-24-2010, 10:52 PM
pun1sh3rz's Avatar
Video please
Quick Reply: Opinions on my intake.
