Going Big
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 20, 2010 | 12:39 AM
GT40MkI's Avatar
2005 E55 / 2001 e39 M5
I just picked up a couple of "no restriction" acres in canyon lake...you know any good guys up here? Looking to build a concrete block fortress of a garage...probably 30x40 or 40x60 and looking to put an apartment/studio of sorts upstairs...lmk. Yours looks awesome-I would do steel but even insulated they get SOOO damn hot in the sun.
Old May 26, 2010 | 10:04 PM
98aggie's Avatar
Chevy Camaro
front pad poured today (5/26/10)
Metal work finished up yesterday also
Original shop still in disarray but will get cleaned up soon
Old May 27, 2010 | 10:02 AM
HadiLaw's Avatar
2004 E55
Wow Kurt, The shop is great! Can't wait for the dyno day on June 5th!
Old May 27, 2010 | 05:55 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Going Big?? At 6`- 8" inches tall, how much bigger you going to get?
Really, place looks great! Hadi has some 400 dollar a bottle champagne to break over the building for good luck!! Isnt he a nice guy? I think he has another bottle to wash down the BBQ with..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 29, 2010 | 07:41 PM
98aggie's Avatar
Chevy Camaro
Had Morgan Carter of Spray Right Insulation come today and spray 2lb foam on the new shop and inclosed car port area. He will be coming back in a month or so when I am ready to foam my new living area.
His contact information is http://www.sprayrightinsulation.com or 877-922-4220
Very nice fellow and has been great to deal with and will travel to jobs in the Texas/Louisiana area
I'm impressed with this stuff. It was 95 degrees today, and inside the shop was a scorcher. Once he was done spraying the foam it wasn't to bad in there. You could feel a little heat coming through the wall (Direct Sun). But I only spray an 1 to 1.5" of foam. On the walls were I had the 3" fiberglass insulation it was hard to hold your hand to it because it was so hot.
It has a slight green tint to it. I am going to start on Monday painting it white, then seal the concrete.
Old Jun 5, 2010 | 12:05 AM
98aggie's Avatar
Chevy Camaro
Finished Paint and Sealer
Moved some cars over today - going to take awhile to get everything moved over and organized now.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
