One step colder plugs???
I'm not sure what should be considered when trying colder plugs but I figure since I'm making more hp than stock the extra protection against detonation would be helpful. Here are a few specific questions I have. (1) Since I use ice at the track will this be problem (2) In cooler weather are members noticing any kind of drive-ability issues (3) Is there a chance of losing any kind of performance gains
Like I said, I know this has been discussed before but some time has passed I'm hoping for a little feedback. I also spoke to a couple of member and they seem to think it's a good idea.
Edit: I have a CLK55 and not an E55 so take it for what it's worth
Item model number: LFR7AIX
The ‘A’ in the OE NGK ILFR6A plug designation refers to their relatively unusual 26.5 mm/1.04 inch reach.
Be aware that Denso’s IK16/20/22 variants have only 19 mm/.750 inch worth of threads.
They’ll screw in just fine, although ignition efficiency will be dramatically reduced.
"Plug sticks through .350 on the deepest part (center of piston chamber) . About .290 on other side of plug.. Looks like about one thread comes through the chamber.."
One steel thread in the chamber is a No-No from a performance stand point, One of the main objectives in keeping knock down is reducing sharp edges in the chamber, If you have heated metal up you will noticed the what gets hot first is the thin edges and points, same thing happens in the chamber, when it gets hot enough that edge will ignite the fuel instead of the spark plug. Now in the real world I cant tell you if this happens in our car with one thread sticking through or not but I can tell you I run what some woulds say is a "short plug" in mine with no notice of imparied drivablity.
I need plugs soon..
NGK LFR7AIX is 1 colder step than stock...
16x $7.85 is not bad for something that does not need replacing for another couple of years.
Amazon has them.. but wondering if a better price is available.
colder plug and it's time I listen. I'll keep ya guys posted.
Thanks again for all the input!!! Good stuff guys.
