Front bumper removal???
Its really not that hard...There are bolts on the bottom once you remove the plastic and also obviously on top. The ones inside your wheel well are a little more difficult and there is a slide bracket that is a connector between both your bumper and fender...>You have to push that bracket forward and then inside to remove and its easier to put on if you put some soap or a little grease on it.
Try using google and do a search, there is DIY up there somewhere. But its really not that bad.
E55
Thanks wizo. I found a DIY from Benzworld.
Here's a link for anybody who needs it:
http://www.benzworld.org/forums/w211...nt-bumper.html
