Need help deciding which mod to go with
Hi guys, I need some help deciding what kind of pulley and ecu tune for my e55. My two chose as of now is kleemen pullies and the ecu tune or the eurocharged pulley system and ecu. Any1 know which will be a greater hp/tq gain?
Check out this Kleemann video... http://www.youtube.com/watch?v=mE_VpRKW838
It really demonstrates the great pride they take in building a product made with precision. Nothing against Eurocharged. I imagine ASP has a high level of QA too.
A Prius because I'm green
I'd go with Kleeman if you were basing it off quality and if you are not going to upgrade the cooling system with a better heat exchanger. Their smaller pulley will be just fine without upgrading that, also there are members on here running great times without the 180 pulley. I personally recommend doing the 180 pulley from ASP if you want the most power but are you planning on upgrading other areas down the road?
///AMG
'13 GT-R AMS Alpha 9+, CLA45, E55
https://mbworld.org/forums/w211-amg/...eemann-k1.html
Well then the best mod you can do for the most power is the EV12 conversion and put a v12 TT from a 65 in it! How's that sound for power?
Thanks everyone for there input, I think I'm deciding to get eurocharged 180mm pulley and LET ecu tune along w/ euro's heat exchange. Will put up results as soon as I get it. Again thanks a bunch
