Knock sensor voltage?
Old Apr 24, 2010 | 11:23 AM
bassn_07's Avatar
2006 E55 AMG
I monitor knock on my car with my Dashdaq/Zeitronix and I get the reading in voltage. What would be acceptable voltage numbers in regards to knock? My numbers will fluctuate between .02 - .06, this both during idle and at WOT. I had no idea what safe values to use but I put 100 octane gas in my car with my 91 tune. Doing this allowed me to see what numbers I should be using and what's typical for a run with no knock, I am assuming that I'm not knocking with 100 octane gas. My results were the same as my WOT runs with 91.....
I've done this a while ago and after reading a few articles it just got me curious to know what values are acceptable.
Old Apr 24, 2010 | 11:38 PM
bassn_07's Avatar
2006 E55 AMG
Guru's needed!!!!
Old Apr 25, 2010 | 12:19 PM
alltrac's Avatar
2004 E55
i have no answers on the knock voltage, but how did the 1-step colder plugs work out for u?
Old Apr 25, 2010 | 12:23 PM
bassn_07's Avatar
2006 E55 AMG
I still haven't installed them yet. I'll hopefully get it done this week and I don't foresee and problems.
Old Sep 25, 2011 | 09:14 AM
jmb614's Avatar
E55 AMG
While I hate to resurrect an old thread I too have the same question. Are you able to monitor knock with the Zeitronix successfully? Or are you having to use something like a Vishnu Knock Buffer in tandem?
Old Mar 11, 2012 | 04:01 PM
cij911's Avatar
one car at a time
Can we not log what the ECU is seeing as knock ?
Old Aug 13, 2014 | 01:58 PM
jmb614's Avatar
E55 AMG
Has anyone with the dashdaq/zeitronix combo been able to successfully log and filter the factory knock sensors to be able to provide a useful analysis? Or is an aftermarket knock sensor/logger the only viable option?
Old Aug 13, 2014 | 02:02 PM
Hulk's Avatar
A Merc
Aftermarket is the only viable option, I tried with the zt2 and it just doesn't work, actually look at other threads from bassn and you will see it never was working 100%, don't waste your time
Old Aug 13, 2014 | 02:07 PM
jmb614's Avatar
E55 AMG
Bummer
Old Aug 13, 2014 | 02:23 PM
Hulk's Avatar
A Merc
If you log all parameters real time and then only use the timing via obd you will see very clearly if there's knock, if your timing is at 17* for example and then it goes down to 4 or 6 for example, that's knock
Old Aug 13, 2014 | 02:46 PM
jmb614's Avatar
E55 AMG
Good point
