Do we have a sensor for low trany fluid ?
I can't imagine we don't have a sensor for low trany fluid.
I had a leak from the radiator pipe going to trany, it was leaking for almost a week and lost more than 2 liters of fluid and no check eng. or any code poped up.
luckily I found the leak before I damaged the trany.
It was the seal attached to the radiator and the cooling pipe going to the trany.
I never thought it was the trany fluid coz it was yellowish color and my eng. oil level was ok.
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
There is no such thing as "sealed for life" or "lifetime fluids" it's all BS. They tell you this, so when your tranny gives up the ghost, they make a ton of money fixing it. Your transmission needs servicing just like any other automatic transmission. I recommend having a full transmission service every 40K, including the torque converter and filter change. This is the guidance that, I received from my shop manager. BMW says this as well, to lower the cost of ownership. But when it's breaks, after the warranty is up, it didn't lower the cost of ownership, but increased it substantially $$$$. Trust me have a full tranny service done, and not a tranny flush. Transmission are expensive to replace in a AMG.
What is the difference between a normal tranny service where you drain the fluid, change the filter and fill it back up and a full tranny service?
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
A tranny flush is simply that a transmission fluid flush, undo the transmission and torque converter drain plug, empty and refill.
The transmissions fluid service is when we replace the transmission oil pan gasket, new o rings, filter, and the electrical connector.
About a $400 dollar service.
As for the fluid, you would want to use MB part # 001 989 68 03 10
Thanks James. I just assumed you would replace the filter and gasket so it's nothing fancy. That's pretty much what I had done at around 50k. I've heard of the pressurized, complete flushes where they flow clean fluid through the entire transmission but I avoided that after hearing some bad stories. Don't always have to reinvent the wheel.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Corret me if I am wrong, but the 722.xxx has only one drain plug to drain the fluid form the transmission casing, the fluid in the torque convertor cannot be drain. the only way to flush the tq convertor is to do a drain and refill a couple off time and cycle the car through all the gears.
