Old 06-24-2015, 01:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Air Intake and Exhaust Guides
Print Wikipost
Need some help 80/82mm Throttle Body For e55
Old 05-07-2010, 12:11 PM
mxzxracer16's Avatar
E 55
Hey guy's I have been getting mixed ideas on what will work. I have an 2005 e55 Longtube headers custom exhaust pulley,intercooler,pump, tunning. Im looking to add a throttle body now. Does anyone know the stock size? And is the 80 mm throttle body direct bolt on besides intake pipe? Also does the 550 82mm throttle bodies bolt up fairly easy with modified mounting? any help would be great. THANKS
Old 05-07-2010, 12:49 PM
blackbenzz's Avatar
haters crazy
Stock TB is 74mm. "80"mm TB is actually 78mm. You can get a 80mm sc inlet and the 80mm TB will bolt to it and get the 80mm y pipe. You need to switch pins for the 80mm TB since it opens in the opposite orientation in comparison to stock. 82mm requires an adapter, porting, and some massaging of the 80mm ypipe to work but no switching pins if you buy a MB TB. Hope that helps and good luck
Old 05-07-2010, 01:46 PM
E 55
Thanks alot. Does anyone know where I can get the adapter plate for the 82mm Throttle body? Thats the only pieace that has me from not doing this swap. THANKS again
Adam
Old 05-07-2010, 01:56 PM
blackbenzz's Avatar
haters crazy
You also need to port the sc inlet, don't forget that part.
Old 05-07-2010, 03:00 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
Could you just buy a used 550 throttle body and Y-pipe and be good to go as far as hardware? Seems silly to buy a kit for $1,800 if it's that simple. I've even been considering doing a custom Y-pipe and intake setup but I'm not there yet.
Old 05-07-2010, 04:04 PM
E 55
Allegedly Im working on it now. I have the throttle body already. Thats why im looking for pointers.
Old 05-07-2010, 04:34 PM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
but where do you find a e550 throttle body
Old 05-07-2010, 06:23 PM
Luke_M's Avatar
Cool. Would you be so kind as to keep me informed when you find something out? I tend to lose track of my posts here and don't always follow up lol
blackbenzz's Avatar
haters crazy
No, you need to modify the sc inlet
Old 05-07-2010, 07:28 PM
Luke_M's Avatar
I got that part too. I was thinking any machine shop or a good mechanic could do this. I just didn't know how involved it was. I have a lot of faith in my guy. I guess my question was, is this a part you have to buy. If you can just modify it fairly easily then that's what I was looking for.
I assume the Y-pipe is off the same S550 as well.
P_benz (07-14-2019)
Old 05-07-2010, 08:41 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
A1131400912
Is the part number for the MB 80mm plenum, or SC inlet
This for the OE MB 80mm ttb. If you are installing an 82, you would have to modify it in order to fit.
Im doing exactly this job right now.
Im installing an 82mm Audi TB, and waiting for this plenun.
I'll let you know how it goes when it finish
GL
Old 05-07-2010, 10:08 PM
E 55
Hey how come you opted for an AUDI throttle body and not an 550 MB t/b? Just curious I have an MB 550 actuator plug and play. Need to get a spacer machined now and port the sc
Old 05-08-2010, 01:00 AM
blackbenzz's Avatar
haters crazy
Nope. The 550 is naturally aspirated and has an elbow that connects to the TB. No ypipe
MB TB is the way to go. Plug and play
Old 05-10-2010, 12:47 AM
OPTIONII's Avatar
98 c43, 2004 e55, 1997 toyota supra turbo, 1994 rx7 LS6/T56
so which MB cars come with 80m TB stock?
Old 04-05-2015, 12:34 PM
Plataille's Avatar
E55
bump, lots of good information here for this swap, and the information as to which cars have the 80mm stock TB would be beneficial for everyone.
Old 04-05-2015, 11:19 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
the SL55 in 07/08 I think is the only car that got the 80mm stock.
Old 04-06-2015, 02:49 PM
Robert AMG's Avatar
Cls63 & C32
Early Sl55 w230 german version 2002 has the 80mm tb stock.
Old 04-06-2015, 03:20 PM
Plataille's Avatar
E55
s550 is 82mm stock, just got it measured
Old 04-07-2015, 11:44 PM
carguyshu's Avatar
I was referencing the 55k motors. You need a Y pipe from an 07 or 08 SL as well as the SC inlet from one in addition to the throttle body.
Old 04-08-2015, 12:08 AM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
MB equipped 80mm in SL55 only from "2007 to 2011" with Engine #: (113.995), instead of 74mm from "2003 to 2006", with Engine #: (113.992)...!
ZAYED,,
Old 04-08-2015, 10:20 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
So, do any larger TBs fit without modifying the S/C inlet?
Old 04-08-2015, 10:47 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
no sir
Old 04-09-2015, 03:49 PM
2000UZJ's Avatar
E55
Will a E550 82MM TB work?
Old 04-09-2015, 05:01 PM
Robert AMG's Avatar
Cls63 & C32
ZAYED,,
i don't know from where did u get those info!
from 2 weeks i got in the garage an sl55 german version model 2002 supercharger stock car with vin wdb2304741f020843, this car has the 80mm tb from factory!! to proove that, attached are pics from EPC for this car, first picture to show u that this car has the engine 113.992 and delivery date 23/5/2002, the second picture is to show tb part nb (80mm) where they mentioned "up to end of model year 2002"
those will verify what i have said in my post above.
Need some help 80/82mm Throttle Body For e55-imag1247.jpgNeed some help 80/82mm Throttle Body For e55-imag1248.jpg
Old 04-09-2015, 05:18 PM
carguyshu's Avatar
Attachment 307435Attachment 307436
yea early 02 SL55 in europe got them, but in the US only 07/08 SL55 got them.
Quick Reply: Need some help 80/82mm Throttle Body For e55
