e55 question
Old May 7, 2010 | 04:13 PM
texasdirtyrice's Avatar
e55 amg
e55 question
a while back my girl friend rolled down my window with the key fob. we had no idea how she did it. in my last car all i had to do was hold down the unlock button to roll down and lock to roll up. i tried the same thing over and over again.. but all i do is turn on the fog lights.
Old May 7, 2010 | 04:19 PM
NORCAL///AMG's Avatar
E CLASS
Old May 7, 2010 | 04:49 PM
squidj's Avatar
2006 E55 (white); 2016 GL 550 (white)
Make sure you are aiming the fob at the drivers door sensor when you are trying it.
Old May 7, 2010 | 05:21 PM
BenzHawaii's Avatar
W211 E55 AMG, W211 E320, R170 350, E46 325ci, NSX, EF8 Crx, CF R6
+1 You have to be within 1 meter or so from the fob on the driver door. I've tried from a far and doesn't seem to work.
Old May 7, 2010 | 05:22 PM
e55 amg
here's the weird thing.. she was on the passenger side when the window rolled down.. about 4 feet away from the car...
Old May 7, 2010 | 05:24 PM
BenzHawaii's Avatar
Hmmm interesting. I'd say just try again at the driver door. Should work.
Old May 7, 2010 | 06:15 PM
MrKool's Avatar
you have to press the unlock button once and then press again and hold. That rolls down ALL windows and opens moonroof.
Same thing for rolling them up but with the "lock" button instead of unlock.
Old May 7, 2010 | 06:29 PM
raymond g-'s Avatar
99 E320
look closely at the exterior of your front door handles. small IR receiver.
press and hold the open/close button. you'll need to stand closer during
brigh sunlight....can stand further back during night.
Old May 7, 2010 | 06:50 PM
dmyrick's Avatar
C63
maybe it's because she's better looking than you.
Old May 7, 2010 | 07:28 PM
BenzHawaii's Avatar
Old May 7, 2010 | 10:11 PM
e55 amg
she is
Old May 7, 2010 | 10:26 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Sometimes the programming gets lost.... I was always able to do this on my car then all of a sudden it just stopped working, then I took it to the dealership and they reprogrammed it I guess. Did you happen to disconnect the car battery or key battery between the time it worked and the time it didn't by any chance?
Old May 8, 2010 | 01:40 PM
e55 amg
never disconnect the car battery.. but i have changed the key batteries a couple of times.
